Published: Thursday, September 28, 2023 - 11:00 (NewTek: Pennsauken, NJ) -- NewTek GAR series spring-loaded gage heads are used in automated dimensional gaging applications as part of inline inspection processes where the sensor probe must move out of the way between readings. The probes of these LVDTs extend when taking dimensional measurements, then retract to their original position to avoid damage to the sensor and prevent damaging the next conveyed product. In manufacturing conveyor lines, these air-extend/spring-retract gage heads conduct tolerance checks as part of quality assurance measures. The LVDTs provide dimensional feedback to verify whether parts have any variance in size and other physical properties. Tolerance checks are important to maintain product quality from lot to lot throughout manufacturing cycles. Machine manufacturers and quality control departments often use these sensors for “go/no-go” inspection of complex mechanical parts. The GAR series gage head sensors check dimensions when their probes contact the measured object. In operation, low-pressure air (10–40 psi) extends the sensor shaft. Probe contact force is regulated by the air pressure. With the removal of air pressure, an internal spring retracts the probe to allow room for automated parts to move along the conveyor without damaging the probe or next product. These AC-operated LVDT position sensors interface with LVDT signal conditioners that provide AC excitation while retrieving the sensor’s unconditioned position output for conversion into analog or digital output that is communicated to a QC data collection system for online quality control and post-process statistical analysis. The GAR series gage heads are customizable with DC outputs of 0-10 VDC, ±10 VDC, or loop-powered 4-20 mA. In construction, the sensors consist of an LVDT assembly with a core connected to a spring-loaded probe shaft having a removable tip. The electrical connection is made through a radially mounted connector, resulting in a reduced housing length. The GAR series windings are potted inside its housing with a two-component epoxy, providing excellent protection against hostile environments. NewTek offers a choice of probe contact tips to address different applications. Designed for a wide range of position measurement and dimensional gaging applications, the sensors offer measurement ranges of ±0.50 in. (1.27 mm) to ±2 in. (50 mm). Shock- and vibration-tolerant, they operate in a wide temperature range of –65°F to 275°F. For more information, visit https://www.newteksensors.com/lvdt-sensors/gar-750-series/. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.NewTek Gage Head Sensors Avoid Damage Between Inspection Readings
Air-extend/spring-retract moves probe out of the way
Quality Digest Discuss
