Featured Product
Innovation Features
Rupa Mahanti
Understanding data decay
NIST
AI monitors real-time data from the physical system
Katie Rapp
The future of manufacturing is about making processes more efficient
Ray Hein
It’s time to lean in to smart technology to help close the skills gap
Adam Zewe
The chip could enable lower-cost devices that perform better and use less hardware
More Features
Innovation News
Ultrasonic flaw detector now has B/C scan capability, improved connectivity, and an app to aid inspection
Tapping tooz for AR/VR competence center
Provides opportunities to deepen leadership capabilities
ASI Construction partners with end users to deliver solutions to production operations
New technology can reduce pollution, bolster energy storage
KCP25C grade with KENGold coating sets new standard for wear and productivity in steel turning
Resistant to high-pressure environments, and their 3/8-in. diameter size fits tight spaces
Algorithms protect data created and transmitted by IoT and other small electronics
More News
Innovation
New Marposs Solution for Inspecting Welds on Pouch Cell Batteries
Using noncontact, interferometric technology
Published: Wednesday, January 18, 2023 - 12:59
(Marposs: Auburn Hills, MI) -- Marposs, a global leader in measurement, inspection, and test technologies, has announced a solution for checking the welding joint of pouch cell batteries within the production process. Comprising interferometric sensors and an NCG (noncontact gauge) controller, the system works by splitting light into two beams that travel different optical paths and are then combined to produce interference, which can identify refractive changes and surface irregularities.
Pouch cell batteries are typically sealed using impulse or contact welding (heat sealing), which fuses the plastic layers together. The thickness of this joint is a key indicator of the quality of the seal and must be measured while the material is still soft. Marposs is able to check this thickness right after the welding process using its noncontact, interferometric technology.
The technique can measure thin, external plastic layers starting at 1 µm, as well as accommodate thickness variations due to the presence of the tabs in parts of the welding seam. The pouch-cell measuring solution includes a measuring snap with two interferometric sensors that enable the simultaneous measurement of the total thickness of the welding seam and the thickness of the two external plastic layers. Each sensor has a measuring field of 900/1.8 mm and offers a repeatability range within 1 mm of the application thickness.
The basic configuration features the NCG controller, a high-speed elaboration gauge that can be connected to any machine for accurate and fast part-thickness control. Optional offerings include a Marposs 9066 industrial PC with Quick SPC software for statistical elaboration and data transfer. Special gauging solutions can be configured to measure the weld thickness in multiple positions, or to fully scan the welding seam along the complete perimeter of the pouch cell.
For more information on solutions for electrical testing of battery cells, visit Marposs interferometric gauge.
Marposs’ in-process solution for inspecting the weld thickness in pouch cell batteries
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
