Featured Product
Innovation Features
Rupa Mahanti
Understanding data decay
NIST
AI monitors real-time data from the physical system
Katie Rapp
The future of manufacturing is about making processes more efficient
Ray Hein
It’s time to lean in to smart technology to help close the skills gap
Adam Zewe
The chip could enable lower-cost devices that perform better and use less hardware
More Features
Innovation News
Ultrasonic flaw detector now has B/C scan capability, improved connectivity, and an app to aid inspection
Tapping tooz for AR/VR competence center
Provides opportunities to deepen leadership capabilities
ASI Construction partners with end users to deliver solutions to production operations
New technology can reduce pollution, bolster energy storage
KCP25C grade with KENGold coating sets new standard for wear and productivity in steel turning
Resistant to high-pressure environments, and their 3/8-in. diameter size fits tight spaces
Algorithms protect data created and transmitted by IoT and other small electronics
More News
Innovation
Mariani Selects Advanced Optical Sorter From Key Technology
Quality doesn’t have to sacrifice efficiency
Published: Wednesday, January 18, 2023 - 12:58
(Key Technology: Walla Walla, WA) -- Mariani has led the dried fruit industry for 115 years by focusing on product quality along with production efficiency. Last year, the company decided to integrate grading and sorting on one prune-processing line at its Marysville, California, facility and began searching for the ideal sorter for this application. Mariani selected a state-of-the-art VERYX optical sorter from Key Technology to find and remove all kinds of foreign material (FM) and the right amount of product defects to make grade while maximizing yield.
“We needed a new sorter to replace a 12-year-old stand-alone sorter that required us to size-grade prunes before sorting; it was an inefficient process, to say the least,” says Andrew Kennedy, director of grower relations at Mariani. “We talked with several suppliers and decided to go with Key Technology. VERYX gives us more advanced sorting capabilities as well as a higher throughput in a smaller footprint.”
To achieve its food safety and product quality objectives, Mariani selected a VERYX C140 chute-fed sorter equipped with front- and back-mounted color cameras, laser scanners, and Key’s proprietary Pixel Fusion detection module. Recognizing the color, size, shape, and structural property of every object, Mariani’s VERYX is programmed to find and eject defects such as scabs, cracks, exposed meat, and brown rot, as well as all types of FM such as glass, rocks, plastic, insects, animal parts, extraneous vegetative matter (EVM), and more.
“Since a lot of our growers are diversified and grow several different crops, it’s not unusual for us to see some cross-contamination,” says Kennedy. “With VERYX, we’ve got a tool that finds even the most difficult-to-detect FM and defects. Among other things, we’ve virtually eliminated all Class 1 FM, which includes allergens like little pieces of almonds and walnuts that can come from neighboring growing fields. This is a game changer for us.”
“VERYX actually outperforms our old sorter in many ways,” says Mark Krause, Marysville plant manager at Mariani. “For one thing, our old sorter inspected product from the top only, so it couldn’t see every defect. Now, thanks to VERYX, we’re accomplishing all-sided surface inspection, which is essential for prunes since they can present defects on any side. With no blind spots, we’ve got a more accurate sort.”
“We’re also able to better maintain sort accuracy over our long production cycles,” says Krause. “Our old sorter got bogged down with product buildup, and that buildup could make the sorter fire its ejectors either too often or not at all. We would have to clean the old sorter during the production run, but that had problems too because when prunes get wet, FM tends to stick to good product. But VERYX is designed to minimize product buildup. It performs perfectly with no midshift washdowns.”
Prior to installing VERYX, Mariani had to size-grade on a separate line due to the old sorter’s limitations. Back then, the company needed 10 workers over two eight-hour shifts to keep pace with incoming product. VERYX has improved sort performance and increased sort capacity, integrating sorting and grading on one line. This year, Mariani is producing the same volume of prunes in only one 10-hour shift with only six workers.
“Reducing our labor requirements with automation means we can give our full-time people a better work environment at the same time we need fewer seasonal workers, which is a huge relief in this tight labor market,” says Krause. “We need only one VERYX operator, and once he starts up the line, he can go do other things. VERYX basically runs itself.”
“Key’s remote monitoring service supports our in-house team and adds to our high confidence that we’re achieving peak performance,” Krause says. “With remote monitoring on VERYX, a Key technician can access and adjust settings on the sorter remotely, if needed. Without it, we’d have to either make an appointment with an in-person technician or trade photos on email to troubleshoot a problem. While we haven’t really had any problems or downtime since we started using VERYX, we did have the opportunity to use remote monitoring once, shortly after installation, to make a minor tweak to a setting. Key was able to make this small adjustment and optimize our sorter’s performance very quickly. Key’s customer service is always stellar. They take the time to really understand our environment and our goals.”
During its seven- to eight-month season, Mariani typically runs 13,000 to 14,000 lb of product per hour on its new prune-sorting and grading line. Since VERYX C140 is rated to sort up to 20,000 lb of prunes per hour, there’s room to grow. After the prunes are sorted and graded at the Marysville plant, they’re sent to Mariani’s Vacaville plant 70 miles away for further processing. Overall, Mariani is producing more than 300 million lb of fruit annually at five manufacturing facilities, offering Mariani-branded and private-label retail packs as well as bulk ingredients to other food processors worldwide.
“VERYX is a more valuable tool than we anticipated,” says Kennedy. “The severe drought in California has brought new challenges. Recent prune crops are smaller than usual, and the quality of incoming product has suffered. It would’ve been hard for us to satisfy customer demand with our old sorting setup. VERYX enables us to achieve our final product quality specifications despite wide fluctuations in raw product quality. At the same time, it also maximizes yield, improves efficiency, and eases labor requirements. Our VERYX sorter is helping us accomplish all our goals.”
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
