Our landlords thank you.
Published: Thursday, January 12, 2023 - 13:01 (WFL Millturn Technologies: Linz, Austria) -- The classic Millturn complete machining center ushered in a completely new era in its original version more than 25 years ago. It was the first WFL Millturn with an individual tool carrier for turning, drilling, and milling with a B axis. Many of these old M30 machines are still in use and delivering top performance, even after many years—so we decided to take a closer look at one of these “proto” Millturns. Although the details of the current design have very little in common with its original version, the stable 60° slant bed is still there. Noteworthy features include the powerful headstock with 37 kW main drive and 2-speed gearbox as well as external C axis. Although the design dates back to the earlier Voest-Alpine WNC slant-bed machines, it is still used in the latest Millturn models of the M35, M40, and M50 series with modernized drive motors. Water-cooled direct drives are available as alternatives. The first machines in the M30 series still had a 24-space magazine with automatic tool changer permanently mounted on the milling unit. Soon this magazine was replaced by an external magazine over the left-hand headstock that was much easier to operate and had an initial capacity of 48 tool stations (a lot back then). This made setting up the tools parallel to machining time possible for the first time. Capacity was then expanded to up to 96 tool stations. Due to the higher power and stricter stability requirements, the system size had to be increased to HSK63 or Capto C6 for current models. The Siemens Sinumerik 880T was initially used as the control system for the first machines. Data memories of this control system were still in EPROM form, writable and erasable only with a special device. The newer machines were then delivered with the Sinumerik 840 C, which already had a hard drive for data storage. Depending on the configuration, the machine had up to nine NC machining axes and was even capable of performing 5-axis interpolations. However, due to the lack of corresponding software solutions for the programming, this was a difficult and laborious undertaking. Thanks to the B-axis with 7.5 kW milling drive and 4,000 rpm, complex and highly precise oblique machining was possible with high productivity. At the time, a new feature was a compressor cooling unit to stabilize the temperature of the turning-boring-milling unit. However, heat from the high continuous speeds was the Achilles’ heel of the turning-boring-milling unit; permanent grease lubrication was simply not sufficient. It was only with the newer models—which featured oil mist lubrication—that this problem was solved. When it came to turning, the machines were unbeatable and were used in aerospace and automotive sectors, for hydraulic components, in mechanical engineering, manufacture, and medical technology for complex precision parts made from difficult-to-machine materials. Today’s models still benefit from the experience gained from serving customers’ requests for decades. Ultimately, the machine is the means for exploiting all technological possibilities to the maximum. Then, as now, technological innovations require a solid foundation. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.Looking at the M30 Millturn, a Longtime Favorite
WFL continues a legacy of success
The modern M30 (left) and its ancestor
Quality Digest Discuss
