Featured Product
Innovation Features
Jennifer Chu
High-speed experiments help identify lightweight, protective ‘metamaterials’
Michael King
Augmenting and empowering life-science professionals
Rich Nobliski
Helping narrow the manufacturing skills gap with 3D tech
NIST
NIST scientists perfect miniaturized technique
Kristi McDermott
Technology and what the future requires for patients and providers to thrive
More Features
Innovation News
New tool presents precise, holistic picture of devices, materials
Enables better imaging in small spaces
Helping mines transform measurement of blast movement
Handles materials as thick as 0.5 in., including steel
For companies using TLS 1.3 while performing required audits on incoming internet traffic
Accelerates service and drives manufacturing profitability
Process contains leaks, improves thermal performance in buildings
Delivered by SpaceX launch to demonstrate in-space capabilities
Recognized among early adopters as a leading innovation for the life sciences industry
More News
Gwendolyn Galsworth
Innovation
Visuality at Work: A More Complete Description
A visual workplace can improve productivity by as much as 30%
Published: Monday, November 14, 2016 - 10:05
In a visual workplace, information is converted into simple, universally understood visual devices and installed in the process of work itself, as close to the point of use as possible. The result transforms a formerly mute work environment into one that speaks, eloquently and precisely, about how to use it effectively and efficiently.
The most complete example of this outside the workplace is our system of roads and highways. In the United States alone, 150 million cars are on the road every day—150 million killing machines. And yet relatively few people die, proportionally only the tiniest fraction of the sum, thanks to visual information sharing.
The vast array of visual devices that populate our roads and highways makes it possible for drivers everywhere to get precisely where they want to go, safely, and on time—day after day, week after week, year after year. Those devices include (but are by no means limited to): exit and speed signs, speed bumps, white lines marking the sides of road, other white lines that guide us through a sharp turn to the left or right, center yellow lines—dashed and solid. This is the language of driver safety imbedded into the roadway itself and the operational language of a large portion of our national economy. That economy would collapse without roads and highways that speak.
You have only to erase these roadway visual devices in your mind’s eye to instantly understand their power and feel appreciation for their functionality. Yes, visuality takes the struggle out of our everyday life. Why not also at work?
Workplace information can change quickly and often—production schedules, customer requirements, engineering specifications, operational methods, tooling and fixtures, material procurement, work-in-process, and the thousand other details on which the daily life of the enterprise depends. In any single day, literally hundreds of precise data points (information) are required to keep work going. And these data points can and often do change dozens of times every shift, with multiples that are enormous.
In the pre-visual workplace, everything and everyone is forced to exist within a narrow definition of their capability. The physical work environment is devoid of definition or conveyed context. It’s devoid of meaning. Attempts to improve the process of work invariably fail because even the smallest gains disappear overnight. A pre-visual workplace has no means to sustain them, however hard-won. This is equally true of lean gains.
Workplace visuality (including its subset, visual management) is a strategy for translating the thousands of informational transactions that transpire every day in the life of the enterprise into visible meaning. This visible meaning doesn’t just impact performance; it creates performance. In this way, the visual workplace is a gigantic adherence mechanism that ensures that what is supposed to happen does happen—on time, every time, day or night—because of visual devices and visual mini-systems. This makes visuality mission-critical to spreading and sustaining lean gains.
The effective implementation of visuality in a company can create—and repeatedly has created—dramatic improvements to the bottom line, including a documented 15 percent to 30 percent increase in productivity. But the liberation of information has a further and nearly incalculable positive efect, this time on a company’s work culture. The liberation of information is the liberation of the human will.
Let the workplace speak!
Gwendolyn Galsworth’s picture
Gwendolyn Galsworth
Gwendolyn Galsworth, Ph.D., has been implementing visuality for more than 30 years. She’s focused on codifying the visual workplace concepts, principles, and technologies into a single, coherent sustainable framework of knowledge. Galsworth founded Visual Thinking Inc. in 1991, and in 2005 she launched The Visual-Lean Institute where in-house trainers and external consultants are trained and certified in the Institute’s nine core visual workplace methods. Two of the seven books Galsworth has written received the Shingo Research and Professional Publication Award.
VSM prior to your Visuality efforts
Intel factories very complex vs Telemarketing offices but your ideas apply to both. But my experience is that shop floor Value Stream Mapping focuses the effort. Often Lean ideas gave already been tried but ran out of steam due to lack of focus on the process segment with the most logistical or performance variance.
Which industries have you addressed with greatest success? What prior problem solving systems were attempted and perhaps ran out of steam?
