Featured Product
Innovation Features
Jennifer Chu
High-speed experiments help identify lightweight, protective ‘metamaterials’
Michael King
Augmenting and empowering life-science professionals
Rich Nobliski
Helping narrow the manufacturing skills gap with 3D tech
NIST
NIST scientists perfect miniaturized technique
Kristi McDermott
Technology and what the future requires for patients and providers to thrive
More Features
Innovation News
New tool presents precise, holistic picture of devices, materials
Enables better imaging in small spaces
Helping mines transform measurement of blast movement
Handles materials as thick as 0.5 in., including steel
For companies using TLS 1.3 while performing required audits on incoming internet traffic
Accelerates service and drives manufacturing profitability
Process contains leaks, improves thermal performance in buildings
Delivered by SpaceX launch to demonstrate in-space capabilities
Recognized among early adopters as a leading innovation for the life sciences industry
More News
Automated Precision Inc.
Innovation
What is LADAR?
How do LADAR, LIDAR, and laser radar differ, and what do they do?
Published: Wednesday, July 26, 2023 - 11:03
As industries around the world work to make their process and products not only automated but also autonomous, there has been an explosion in the use of detection and ranging systems during the last 20 years. Detection and ranging systems date back to radar systems that were developed during World War II.
RADAR stands for radio detection and ranging. More modern systems have been developed around light sources, leading to laser radar, light detection and ranging (LIDAR), and laser detection and ranging (LADAR) systems. On the surface, all of these systems are based on similar philosophies, and articles often group them together. But, LIDAR, laser radar, and LADAR actually have some significant technological differences that affect the applications for which they are suited. So, we wanted to take a deep dive on these terms and identify what detection and ranging systems are for and how they differ from each other.
Detection and ranging systems are all based on the same technique of sending a wavelength out into space and using the information of where it bounces off surfaces to create a map of the surrounding area, similarly to how bats use echo location to “see” the area around them without processing visible light. Radar systems use radio waves to detect the space around them, which has the advantage of being able to go through walls, but the longer microwave frequencies have lower resolution and slower measurement speeds.
LIDAR, laser radar, and LADAR all use frequencies from light wavelengths (both visible and invisible to the human eye) to map their surrounding areas. Light waves have higher resolutions than radio waves, which allows for much higher accuracies in the maps they create. But they are more affected by environmental objects and weather conditions. These technologies operate under a principle similar to laser tracking, but their measurements don’t require a target to return the beam to the unit to read positional geometry.
Even though LIDAR, laser radar, and LADAR are all based on the same principle, how they measure and the applications they are appropriate for have some significant distinctions.
Laser radar units typically send out a single, focused laser beam to measure features within a few meters of the unit at accuracies within a handful of microns.
LIDAR has become a catch-all term for all light-based noncontact metrology instruments. But in practice, LIDAR measurement devices have been developed to handle high-volume scans of large areas. They typically send out multiple laser beams in a grid or cone style and use constant motion to cover millions of points quickly, with accuracies ranging from tenths of an inch to more than a foot, depending on the application. LIDAR technology has become commonplace in land surveying and mapping, building information modeling, and guidance systems for self-driving cars.
Laser radar, on the other hand, has developed to more closely replicate laser tracker measurements in noncontact fashion. Laser radar units typically send out a single, focused laser beam to measure features within a few meters of the unit at accuracies within a handful of microns. Laser radar technology has been integrated into manufacturing environments in industries around the world for more automated scanning solutions that can be robot-mounted for near-line inspections.
But for truly automated inspection solutions in manufacturing, including fully in-line measurements, LIDAR lacks the accuracy, and laser radar lacks the speed and efficiency of measurement. LADAR, however, is designed to marry these two technologies. A true LADAR system, like API’s Dynamic 9D LADAR, can use a chirped interferometer laser to provide greater part coverage without sacrificing any accuracy. LADAR systems can be used in all laser radar applications while adding the speed necessary to perform in-line quality inspections for body-in-white or fuselage assembly.
In short, detection and ranging systems use different frequencies of wavelength sent out into space to map an area based on how long it takes the wave to bounce off an obstacle. LIDAR, laser radar, and LADAR technologies all use light frequencies to take these kinds of measurements. But while the principal technology is the same, the practical designs and applications have led to very different uses. LIDAR utilizes more of a grid or cone of laser beams to increase coverage and data collection at longer distances with lower accuracies. Laser radar systems have sacrificed the speed of LIDAR for increased accuracy with a single, focused beam. But a true LADAR system, like API’s Dynamic 9D LADAR, is able to combine that speed and accuracy for more efficient measurement.
Sources
https://spie.org/samples/TT85.pdf
lidarnews.com/articles/whats-the-difference-between-laser-radar-and-lidar-technology
https://www.sensorsinc.com/applications/military/ladar
First published June 5, 2023, on API News.
Automated Precision Inc.’s picture
Founded in 1987 by Kam Lau, Automated Precision Inc. (API) is the inventor and original patent holder on the first laser tracker systems. API develops and manufactures laser trackers; portable coordinate measuring machines (CMMs); laser tracker accessories, which include probes, sensors, targets, cameras, SMRs, and scale bars; and machine tool calibration products. API Technical Services include contract measurement equipment rental, onsite laser tracker calibrations, machine tool error mapping, machine tool alignment, and training for 3-D measurement systems and analysis software. With its world headquarters in Rockville, Maryland, API also has offices in China, Germany, and India.
