Our children thank you.
Bruno Ménard
Published: Wednesday, November 9, 2022 - 12:02 While traditional image processing software relies on task-specific algorithms, deep learning software uses a network to implement user-trained algorithms to recognize good and bad images or regions. Fortunately, the advent of specialized algorithms and graphical user interface (GUI) tools for training neural networks is making it easier, quicker, and more affordable for manufacturers. What can manufacturers expect from these deep-learning GUI tools, and what’s it like using them? Training is the process of “teaching” a deep neural network (DNN) to perform a desired task—such as image classification or converting speech into text—by feeding it data that it can learn from. A DNN makes a prediction about what the data represent. Errors in the prediction are then fed back to the network to update the strength of the connections between the artificial neurons. The more data you feed the DNN, the more it learns, until the DNN is making predictions with a desired level of accuracy. As an example, consider training a DNN designed to identify an image as being one of three different categories: a person, a car, or a mechanical gear. Typically, the data scientist working with the DNN will have a previously assembled training dataset consisting of thousands of images, with each image labeled as a “person,” “car,” or “gear.” This could be an on-the-shelf dataset, such as Google’s Open Images, which includes nine million images, almost 60 million image-level labels, and much more. If the data scientist’s application is too specialized for an existing solution, then they may need to build their own training dataset, collecting and labeling images that will best represent what the DNN needs to learn. During the training process, as each image is passed to the DNN, the DNN makes a prediction (or inference) about what the image represents. Each error is fed back to the network to improve its accuracy in the next prediction. Here the neural network predicts that one image of a “car” is a “gear.” This error is then propagated back through the DNN, and the connections within the network are updated to correct for the error. The next time the same image is presented to the DNN, it will be more likely to make the correct prediction. This training process continues with the images being fed to the DNN and the weights being updated to correct for errors, over and over again, dozens or thousands of times until the DNN is making predictions with the desired accuracy. At this point, the DNN is considered “trained,” and the resulting model is ready to be used to categorize new images. The number of inputs, hidden layers, and outputs of a neural network is highly dependent on the problem you’re trying to solve and the particular design of your neural network. During the training process, a data scientist is trying to guide the DNN model to achieve a desired accuracy. This often requires running many, possibly hundreds, of experiments, trying different DNN designs that vary by number of neurons and layers. Between the input and output lay the neurons and connections of the network—the hidden layers. For many deep learning challenges, one to five layers of neurons are enough, since only a few features are being evaluated to make a prediction. But with more complex tasks, with more variables and considerations, you need more. Working with image or speech data may require a neural network of dozens to hundreds of layers, each performing a specific function, and millions or billions of weights connecting them. Traditionally, hundreds, or even thousands, of manually classified images were required to train the system and create a model that classifies objects with a high degree of predictability. But gathering and annotating such complex datasets has proven an obstacle to development, hindering deep learning adoption in mainstream vision systems. Deep learning is well-suited to environments in which variables—such as lighting, noise, shape, color, and texture—are common. A practical example that shows the strength of deep learning is scratch inspection on textured surfaces like brushed metal. Some scratches are less bright, with a contrast close to the textured background itself. Consequently, traditional techniques usually fail to reliably locate these types of defects, especially when the shape, brightness, and contrast vary from sample to sample. The image below illustrates scratch inspection on metal sheets. Defects are clearly shown via a heatmap image, which highlights the pixels at the location of the defect. A deep neural network trained from scratch typically requires hundreds or even thousands of image samples. However, today’s deep learning software is often pretrained, so users may need only tens of additional samples to adapt the system to their specific application. In contrast, an inspection application built with regular classification would require the collection of both “good” and “bad” images for training. However, with new classification algorithms such as anomaly detection, users can train on good samples only and need only a few bad samples for final testing. Although there’s no magical way to collect image samples, it’s getting much easier. To collect images, technicians can use Sapera LT, a free image-acquisition and -control software development toolkit (SDK) for Teledyne DALSA’S 2D/3D cameras and frame grabbers. Astrocyte, a GUI tool for training neural networks, interfaces to Sapera LT to allow image collection from cameras. A user collecting images on PCB components in manual mode, for example, would move the PCB with their hands, changing the camera position, angle, and distance to generate a series of views of the PCB components. Once the user has the images, it’s time to train the neural network. Training is performed in Astrocyte by simply clicking on the “Train” button to start the training process with the default hyper-parameters. It’s possible to modify the hyper-parameters to achieve better accuracy on the final model. To verify accuracy, the user tests the model with a different set of images and may choose to employ diagnostic tools, such as a confusion matrix, for a classification model. A confusion matrix is an NxN table (where N = the number of classes) that shows the success rate for each class. In the example below, color coding is used to represent the precision/recall success of the model, with green indicating a rate exceeding 90 percent. Heatmaps are another critically important diagnostic tool. For example, when used in anomaly detection, a heatmap highlights the location of defects. When the user sees the heatmap, they assess whether the image is good or bad for the right reasons. If the image was good but was classified as bad, the user can look at the heatmap for more detailed information. The neural network will follow what the user provided as input. This use of heatmaps on a screw-inspection application provides a good example: A heatmap can also reveal that a model is focusing on an image detail or feature that has no relevance to the desired analysis of the target scene or object in the image. Depending on the Astrocyte module, different types of heatmap-generation algorithms are available. The best way to explain the GUI-tool approach to deep learning is to show it. Because anomaly-detection model training is foundational to training neural networks, here’s a brief tutorial with a step-by-step approach to using Astrocyte for anomaly detection. When the generation process is complete, the image size distribution analyzer dialog is displayed if images in the dataset have varying sizes; otherwise, if images all have the same dimensions, they are automatically resized to the specified maximum image size, and the dialog isn’t shown. If necessary, correct images using the Image Correction dialog. Once the training portion is complete with acceptable accuracy, we end up with a weighted neural network, essentially a massive database. This is something that will work well, but perhaps isn’t optimal in terms of speed and power consumption. Some applications won’t tolerate high levels of latency: think intelligent transportation systems or even self-driving cars. Autonomous drones or other battery-powered systems might need to operate within a tight power envelope to meet flight-time requirements. The larger and more complex the DNN, the more compute, memory, and energy is consumed to both train it and run it. This may not work for your given application or device. In such cases, there is a desire to simplify the DNN after training to reduce power and latency, even if this simplification results in a slight reduction in prediction accuracy. This kind of optimization is a relatively new area of deep learning. Chip and AI accelerator vendors typically create software development kits to help their users perform this kind of task—using software specifically tuned for their particular architectures. The chips involved can range widely, from GPUs, CPUs, and FPGAs to neural processors. Each has its own advantages. For example, Nvidia’s TensorRT emphasizes the company’s expertise in GPU cores. Xilink’s Vitis AI, in contrast, supports the company’s SoC like Versal, including CPU, FPGA, and neural processors. Vendors typically offer variations on two types of approaches: pruning and quantization. Pruning is the action of removing parts of the neural network that make less of a contribution to the final result. This reduces the size/complexity of the network without significantly affecting the output precision. The second approach is quantization—reducing the number of bits per weight (for example, replacing FP32 with FP16 or Quantized INT8/4/2). With less complex computation to perform, this can increase speed or reduce the hardware resources needed. Once our DNN model is trained and optimized, it’s time to put it to work making predictions against previously unseen data. This is like the training process, with images being fed as input and the DNN attempting to classify it. The user can implement inference on a PC using a GPU or CPU or on an embedded device. Depending on the size, weight, and power (SWAP) requirements of the application, the user can leverage various technologies for implementing deep learning inference on embedded devices such as GPUs, FPGAs, and specialized neural processors. At their heart, neural networks are complex and powerful tools. There are almost limitless opportunities to tweak and optimize each one to get the best performance for the problem you’re trying to solve. The sheer scope of optimization, and the rapid pace of new research and tools can be overwhelming, even to seasoned practitioners. But that doesn’t mean that you can’t start incorporating the benefits of these tools in your next vision system. The migration toward GUI tools is democratizing deep learning in vision systems. With software that frees users from the rigorous requirements of AI learning and programming experience, manufacturers are using deep learning to analyze images better than any traditional algorithm. One day soon, such GUI tools may outperform any number of human inspectors. Interested in learning more about deep-learning GUI tools for vision applications? Watch this webinar and learn more about Teledyne DALSA vision software. First published Nov. 18, 2022, on Teledyne Imaging. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, With more than 25 years in machine vision, Bruno Ménard is well versed on 2D and 3D image processing as well as artificial intelligence. He has participated in and led projects including filtering, identification, recognition, and measurement algorithms based on image processing and deep learning technologies. He’s also worked in teams mandated to develop and deploy software on various platforms and embedded processors. Since 2016, he has focused on innovation in 3D image analysis and artificial intelligence.From Training to Inference: Creating a Neural Network for Image Recognition
Graphical interfaces make it easier to implement your own deep learning network
Training: Creating the deep learning model
Annotation modalities in Google Open Images: image-level labels, bounding boxes, instance segmentations, and visual relationships.Training
Right-sizing your neural network
Example of simplified multilayer DNN with the kind of tasks individual layers might perform.Getting starting with sample collection
Surface inspection shows a plate of brushed metal with scratches at left, and the heatmap output of a classification algorithm—which is created automatically while training the neural network with input samples—shows the defects at right. Note that we added the yellow circles to show the correspondence between the raw image and the heatmap.Training the neural network with visual tools
In a confusion matrix, double-clicking on result fields opens the associated images in Astrocyte’s Images tab for further investigation.
Astrocyte shows the encircled defect in the upper right through the corresponding heatmap. The perfect image, in contrast, is in the upper left.GUI tool in action
Step 1: Launch the Astrocyte application, and select the Anomaly Detection module from the startup screen.
Step 2: In the Dataset tab, right-click and select Add dataset.
Step 3: Enter the dataset name and description, right-click in the Databases panel, and select Add database.
Step 4: In the Add location dialog, navigate to the folder containing the dataset of training images. Select both normal (good) and anomaly (bad) directories and click OK.
Step 5: For each directory, assign the class label using the drop-down list: Normal or Anomaly. Then click Generate to add the dataset to the internal Astrocyte server.
Step 6: In the Images tab, use the Dataset drop-down list to select the required dataset. Then verify the dataset images and labels, and make any required changes. If the dataset is modified, click Save to update and save the dataset on the Astrocyte server.
Step 7: In the Training tab, select the dataset and click Train; the training loss and metric graphs are updated at the completion of each batch, and training statistics are displayed.
Step 8: When training is complete, a prompt is displayed to save the model; click Yes. Enter the model name and description, and click OK. Now you have a model for testing. Astrocyte also walks the user through that process, using the same intuitive GUI.Optimizing for inference: Do we need to refine our trainee?
Ready for production: moving to inference
Teledyne DALSA offers Sapera Processing and Sherlock, two software packages that feature a suite of image-processing tools and an inference engine for running AI models built from:
Teledyne DALSA software packages for AI training and inferenceDeep learning: easier every day?
Quality Digest Discuss
Bruno Ménard
