Featured Product
Innovation Features
Annet Aris
The digital world has pushed old curves off the whiteboard as new trajectories arise
Larry Hardesty
Electrodes on the face and jaw pick up otherwise undetectable neuromuscular signals triggered by internal verbalizations
A simple definition of innovation is needed
Rick Gould
To aid global sanitation, ISO 31800 will certify the design, performance, and testing of toilets that function off the grid
Innovating Service With Chip Bell
Beware of expectations set by labels
More Features
Innovation News
Deep Reality Viewer creates stereo, high-definition 3D images without using a monitor
Wing’s shape shifts automatically for aerodynamic loads (e.g., takeoff, landing, cruising)
Process concerns technology feasibility, commercial potential, and transition to marketplace
Identifying the 252 needs for workforce development to meet our future is a complex, wicked, and urgent problem
How established companies turn the tables on digital disruptors
Building organizational capability and capacity to create outcomes that matter most
‘What if we could develop electronic systems that we wrap around a bridge or cover the walls of our office?’
System breaks down complex designs into easily modifiable shapes for custom manufacturing and 3D printing
How to solve any problem and make the best decisions by shifting creative mindsets
More News
Doug Devereaux
Innovation
Smaller Manufacturers Get Lean With Artificial Intelligence
Putting the ‘continuous’ in continuous improvement with AI
Published: Wednesday, April 3, 2019 - 12:03
Artificial intelligence (AI) is widely acknowledged as a crucial aspect of what is broadly referred to as Industry 4.0. Although no one knows yet how AI will be incorporated into the next phase of the Industrial Revolution, most agree that it will allow greater connectivity between people, machines, and information technology, allowing manufacturers to better optimize processes and predict problems.
How are small and medium-sized manufacturers, which typically don’t have the time or capital it would take to test emerging technologies, supposed to evaluate how AI could impact their organization—and play a role in preparing them for Industry 4.0?
Waiting for the manufacturing sector to decide, so to speak, is certainly not an option. A delay of one, two, or five years could cause a manufacturer to be left behind. The time to act is now, but the path forward isn’t clear.
One way to address this is to evaluate AI through an ongoing transformation that many small and medium-sized manufacturers have already embraced: lean manufacturing.
Central to lean philosophy is the idea of continuous improvement. It’s a commitment to ongoing change. To do lean, a willingness to change must be maintained at all times so that when an opportunity for improvement is identified, it can be quickly implemented.
Lean improvements proceed through interventions. If a problem is identified, say in a process, work is halted. Team members are called in to observe, draw conclusions, make judgments, and eventually take actions that address the cause of the issue. This intermittent operation is how lean works, although its stop-start rhythm seems fundamentally at odds with the idea of continuous improvement. It’s what is currently feasible, though—or at least humanly possible.
Now, what if you didn’t have to halt work to perform a lean operation? What if you could do the bulk of the fundamental lean process (e.g., observe, draw conclusions, make judgments, take action) while work was happening, making the lean process more continuous? This is one of the main promises of AI for manufacturing operations of any scale.
Where lean operations can start with AI
Artificial intelligence is a vast field that includes a wide range of technologies, everything from algorithms capable of learning from data sets to robots that resemble something out of a science fiction story.
As far as small manufacturers are concerned, the type of AI they should primarily be concerned with is a subdiscipline called machine learning. As Amit Manghani defines it in his “A Primer on Machine Learning”:
“Machine Learning is a form of data analysis,” he writes. “Using algorithms that continuously learn from data, Machine Learning allows computers to recognize hidden patterns without actually being programmed to do so. The key aspect of Machine Learning is that as models are exposed to new data sets, they adapt to produce reliable and consistent output.”
Manghani goes on to outline four types of machine learning, all of which could have applications for lean manufacturing:
1. Supervised machine learning
2. Unsupervised machine learning
3. Semi-supervised machine learning
4. Reinforcement machine learning
This assumes, however, that a small manufacturer is willing to invest in the computing power to make the requisite data available for computational analysis. Let’s explore each of these four opportunities to apply machine learning to lean manufacturing in a bit more detail.
In supervised machine learning, algorithms parse incoming data, assigning labels to any datum that meets predefined criteria. Lean manufacturers could use such a technique to automate quality control for complex parts, for example, assuming relevant part data could be recorded and made available to the algorithm.
With unsupervised machine learning, there are no preordained answers an algorithm can use to sort data. Rather, the algorithm must observe and evaluate data as they accumulate, identifying patterns and creating emergent labels. This type of machine learning could be used by lean manufacturers to monitor a production machine—or a series of networked machines—for unusual behavior and thereby anticipate a malfunction.
As the name indicates, semi-supervised machine learning mixes supervised and unsupervised approaches. In a semi-supervised scenario, there are some existing labels for data. Other criteria are also developed by the algorithm over time with the assistance of human supervision. A semi-supervised scenario could be useful for optimizing repetitive part production, potentially eliminating both part and process waste.
In a reinforcement scenario, an algorithm projects which action, out of a set of possible actions, will result in the highest reward. Small and medium-sized manufacturers engaged in a lean transformation process could use this type of machine learning to weigh different paths toward process-oriented changes they envision.
Machine learning can supplement lean manufacturing
By focusing on machine learning, one can start to see how there are applications for AI that are useful and accessible for most manufacturers, no matter what their size. In some cases, pieces of the puzzle may already be available in the form of data harvested by already-installed machine sensors, existing information technology, and operational technology infrastructure.
As small and medium-sized manufacturers begin to contemplate applications for AI, it’s important to remember that none of these scenarios automatically threaten the availability of jobs for humans. Rather, these ideas can be pursued in a way that is complementary to a worker-empowering lean process by giving employees access to real-time information and better tools for on-the-job problem solving and execution.
A useful analogy is current automobile sensor technology, which supplements human drivers’ awareness and perceptions. Not only does this technology improve safety, it also helps ensure that there is less friction in the overall driving system by aligning the behavior of everyone on the road. In this way, car safety technology doesn’t take anyone out of the driving equation; it makes driving a safer and more efficient experience.
If we take this perspective, AI can be viewed as just another tool in the lean toolbox, albeit one that has the potential to be very powerful.
First published March 6, 2019, on the NIST Manufacturing Innovation blog.
Doug Devereaux’s picture
Doug Devereaux
Doug Devereaux is a Senior Industrial Specialist at MEP, where he focuses on the capture and dissemination of financial resources and strategies that can be used by MEP centers to help manufacturers develop innovative products or expand markets and sales. Over his 25 years experience at the state and federal Departments of Commerce, Doug has led industrial missions to the Pacific Rim and produced various publications involving such topics as laboratory technology transfer, business incubator practices, science and engineering trends in Asia, and community approaches to angel capital investment.
