Featured Product
Innovation Features
Oak Ridge National Laboratory
Hafnium oxide key to novel applications
David Suttle
What is breakthrough technology really capable of?
David Cantor
This article is 97.88% made by human/2.12% by AI
Eric Whitley
Robotic efficiency coupled with human intuition yields a fast, accurate, adaptable manufacturing system
More Features
Innovation News
To be unveiled during PACK EXPO Las Vegas at the Hiperbaric booth, No. N-10857
Educating the next generation of machinists with state-of-the-industry equipment
In a first, researchers have observed how lithium ions flow through a battery interface
Air-extend/spring-retract moves probe out of the way
Precision cutting tools maker gains visibility and process management across product life cycles
Expanded offering includes Smartscope E-series for 3-axis video measurement
Accelerates CAM programming time 80% to make U.S. manufacturers more productive
Pioneers new shape-memory alloys
A Heart for Science initiative brings STEM to young people
More News
Innovation
Motion-Control Technology Aids Precision Automotive Manufacturing
An optimal process requires an innovative control algorithm
Published: Wednesday, June 7, 2023 - 12:02
In metal stamping, especially in critical automotive applications, sometimes it’s not enough simply to close the control loop. Traditional control algorithms rely on eliminating an error between what is happening—as indicated by feedback from system sensors—and what should happen. High-speed motion controllers quickly perform such tasks.
But what if, for product-quality reasons, no striking errors must occur in the first place? For example, what if the risk of making an impression too quickly or too heavily when stamping an automotive part must be avoided? Slowing the press might work, but doing so reduces productivity.
A newly designed hydraulic die cushion, featuring the latest motion-control technology to properly mesh cushion and press-ram action, helps stamping operations at Spartanburg Steel Products meet stringent automotive body-panel forming and precision requirements.
This illustration shows the layout of a die cushion in a press at Spartanburg Steel Products. A rapid development and installation process helped ensure that the manufacturer met part-production requirements for a new automotive-model year.
To perform the process as quickly as possible requires innovation in setting up the control algorithm. Dayton Die Cushions in Eden Prairie, Minnesota, undertakes such innovation, as the following example shows.
Enables tight automotive tolerances
Die cushions, hydraulically operated platforms that reside under the die in the press, move to cushion and oppose the motion of the main press ram. A die cushion typically pinches the periphery of a workpiece with various pad pressures to control the rate at which the workpiece is pressed into the die by the ram. Using die cushions enables the manufacture of automotive components, such as body panels, to tight tolerances and with features such as bends that prove unattainable with press-only stamping operations.
Given such requirements, Dayton Die Cushions manufactured a die cushion and retrofitted it to a stamping press at Spartanburg Steel Products, in Spartanburg, South Carolina. Not initially designed with a die cushion, the press was identified as a candidate by plant managers, who understood that to supply more of the new-generation body panels to automotive manufacturers, they would need the capabilities and precision offered by such a device.
Cushion, motion control meshed to press
Challenges to be met during the retrofit project at Spartanburg Steel Products included fitting the new machine components within the physical constraints of its existing press.
“We had to take the motion of the existing ram into account to make sure that the new cushion could work with it,” says Tom Pedersen, Dayton Die Cushions manager. “The old press had a distorted bed, and we needed to align the structure before we could add our hardware. We reconstituted the bed with adjustable guides that we aligned with a 3D laser to within 0.001 in.”
The new die cushion also needed to contact the workpiece with the press ram already in motion and moving at a high velocity, which in turn required the hydraulics to act before the ram contacted the die. This contrasts with traditional press operations, where the ram hits the cushion before the cushion moves; the contact causes hydraulic pressure to spike and generates an error in the closed-loop algorithm, which produces a response according to the algorithm. However, such a method would not work in the press application at Spartanburg Steel Products.
“We couldn’t tolerate the collision,” Pedersen explains. “Instead, we looked for a way to predict the collision and take action prior to the ram hitting the workpiece.”
Another challenge: responsiveness of the valve. If the cushion’s hydraulic controller waited too long to begin increasing oil flow to the valve, the time lag could damage the workpiece. The hydraulic oil must be moving in time to move the cushion just as the ram readies to make contact.
Dayton Die Cushions’ solution to this challenge was a programmable motion controller that could set up a virtual motion axis to which a physical axis could be geared. “Gearing” refers to the ability of the motion of a slave axis to follow a master axis, which can be another physical axis or a virtual axis that exists only within the motion controller.
“We created a virtual closure of the die-cushion control loop before the ram hits the cushion, which no one had done before,” Pedersen says.
With the virtual control loop closed, oil flow initiates before the die cushion contacts the ram; thus, the two hydraulic systems come together smoothly, even with the ram moving quickly and with tremendous kinetic energy.
To achieve high dynamics, the team at Dayton Die Cushions selected a servo valve with high flow but very low mass. Other objectives include: minimizing the volume of oil flow; reducing the size of the hydraulic power unit; and reducing oil conditioning, i.e., cooling, filtering, etc. Constructing this die-cushion application entirely with hydraulics would make it difficult to ensure the movement of enough hydraulic oil in the volume and time required, because the cushion measures 125 in. x 69 in. and must provide 250 tons of maximum holding force. As a result, Pedersen and his team incorporated two passive pneumatic cylinders beside the hydraulic cylinder to reduce the amount of hydraulic oil to be moved. The pneumatic cylinders provide the base tonnage of the cushion, and the hydraulic cylinder provides the variable tonnage that assists in shaping the workpiece.
To implement the hydraulic controls, Aleksandra Spiess, an engineer at Dayton Die Cushions, selected an RMC75 electrohydraulic motion controller from Delta Computer Systems.
A motion controller from Delta Computer Systems, incorporated to control die-cushion pressure precisely, enables needed pressure throughout the press stroke to aid forming operations.
“The RMC75 can run four separate task-execution engines simultaneously,” Pederson says, noting that within Delta’s RMCTools software, each task also can run any of several user programs, one at a time. “We assigned one of the tasks to be a dedicated computation engine working in the background. A PLC wouldn’t have been fast enough to perform like the RMC.”
The motion controller connects to two servo valves, with each assigned to a separate control axis of the RMC75, which can control two axes simultaneously and independently.
“If needed, we can move extra oil to the tank in order to quickly move the die cushion,” Pedersen says. “The ram moves quickly when the cushion first hits, and then slows down as the compression operation completes.”
Correct pressure timing is a must
The new die cushion uses two Balluff magnetostrictive linear displacement transducers (LDTs) with synchronous serial-interface inputs to the Delta motion controller and Hydac high-speed pressure sensors. One LDT measures ram position, and the other measures cushion position. Just prior to the ram contacting the cushion, the RMC75 opens the valves and begins moving oil through the manifold. Then, at ram contact, the RMC75 runs a pressure-control loop as the cushion descends. At the bottom of the press stroke, as the ram reverses direction and ascends, the RMC is programmed to switch to position-control mode. This causes the die cushion to rise quickly, just in time to meet a robotic arm that picks the finished part out of the die.
“The cushion must ascend in a certain time window, repeatably, to meet the transfer arm,” says Pedersen. “This required that adaptive, closed-loop control occurs as the temperature—and hence, the flow properties of the hydraulic oil—are changing dynamically.”
Another challenge met by the Delta controller: the ability to work with existing off-the-shelf valves used by Dayton Die Cushions, because the lead times for manufacturing new valves stretched too long to meet project goals.
The Dayton Die Cushions team undertook three iterations to complete the motion-control program for the Delta controller.
“As we went through the iterations, Delta’s engineers provided tremendous help,” Pedersen says. “For example, they taught us how to use the RMC75’s S-curve instruction, which initiates a smooth acceleration and deceleration to avoid hydraulic shock. They also helped to incorporate feed-forward parameters into the control loop—predictive terms that help speed response of the control algorithm.”
The team used Delta’s RMCTools Plot Manager software to prove the functionality of the system to graphically and optimally tune the control-loop gains. Saving time in completing the design was important, as Spartanburg Steel Products sought to add tooling quickly in support of part production for the new automotive-model year.
The die cushion design developed by Dayton Die Cushions provides an example of how hydraulic control systems have become smarter to meet the increased productivity and quality demands of modern automotive manufacturing. A key component of how the new machines make this possible is the programmable electro-hydraulic motion controller.
This article originally appeared in the April 2023 issue of MetalForming magazine and is reprinted here with permission from PMA (Precision Metalforming Association) Services Inc.
About The Authors
Aaron Heinrich’s picture
Aaron Heinrich
Aaron Heinrich is responsible for technical support and training at Delta Computer Systems Inc., Battle Ground, Washington.
MetalForming’s picture
MetalForming
MetalForming magazine strives to serve the needs of its readers—engineers, technicians, managers, designers and others working in facilities that add value to sheet metal—by producing the industry’s leading editorial package that combines staff-written and contributed feature articles, expert commentaries, industry news, and state-of-the-art product updates.
