Featured Product
Innovation Features
Robert Zaruda
Connecting education and industry to create careers
Christopher Dancy
Not binding, not enforceable, but a step in the right direction
Scott Ginsburg
A balancing act between getting new technology and bringing it to your people
Zach Winn
Fewer materials, lower manufacturing cost
NIST
Breakthrough could help Nobel-winning tech measure distances and timing with pinpoint precision
More Features
Innovation News
New medical product from Canon’s Video Sensing Division
Features include flexible installation and fast measurement
Guidance for deploying digital twins safely and securely
Electric power is replacing diesel and hydraulics in construction industry
New model promises high-accuracy, 360-degree spherical image capture
Faster, more user-friendly for life sciences
Improved resolution and functionality for high-performance image capture
Innovative technique could be key to reuse
More News
Pacific Northwest National Laboratory
Innovation
Low-Cost and Lightweight
Strongest titanium alloy aims at improving fuel economy and reducing emissions
Published: Tuesday, June 28, 2016 - 15:52
An improved titanium alloy—stronger than any commercial titanium alloy currently on the market—gets its strength from the novel way atoms are arranged to form a special nanostructure. For the first time, researchers have been able to see this alignment and then manipulate it to make the strongest titanium alloy ever developed, and with a lower cost process to boot.
They note in a paper published in April 2016 by Nature Communications that the material is an excellent candidate for producing lighter vehicle parts, and that this newfound understanding may lead to the creation of other high-strength alloys.
Using atom-probe tomography, researchers are able to create an “atomic map” of the arrangement of various atoms in this titanium alloy.
Researchers at the Department of Energy’s Pacific Northwest National Laboratory (PNNL) knew the titanium alloy made from a low-cost process they had previously pioneered had good mechanical properties, but they wanted to know how to make it even stronger. Using powerful electron microscopes and a unique atom-probe imaging approach, they were able to peer deep inside the alloy's nanostructure to see what was happening. Once they understood the nanostructure, they were able to create the strongest titanium alloy ever made.
Mixing it up
At 45-percent the weight of low-carbon steel, titanium is a lightweight but not super-strong element. It’s typically blended with other metals to make it stronger. Fifty years ago, metallurgists tried blending it with inexpensive iron, along with vanadium and aluminum. The resulting alloy, called Ti185, was very strong—but only in places. The mixture tended to clump, just like any recipe can. Iron clustered in certain areas, creating defects known as “beta flecks” in the material, making it difficult to commercially produce this alloy reliably.
About six years ago, PNNL and its collaborators found a way around that problem and also developed a low-cost process to produce the material at an industrial scale, which had not been done before. Instead of starting with molten titanium, the team substituted titanium hydride powder. By using this feedstock, they reduced the processing time by half, and they drastically reduced the energy requirements—resulting in a low-cost process in use now by a company called Advance Materials Inc. ADMA co-developed the process with PNNL metallurgist Curt Lavender and sells the titanium hydride powder and other advanced materials to the aerospace industry and others.
Modern blacksmiths
Much like medieval blacksmiths, researchers knew that they could make this alloy even stronger by heat-treating it. Heating the alloy in a furnace at different temperatures and then plunging it into cold water essentially rearranges the elements at the atomic level in different ways, thereby making the resulting material stronger.
An improved titanium alloy, stronger than any commercial titanium alloy currently on the market, gets its strength from the novel way atoms are arranged to form a special nanostructure. For the first time, researchers at PNNL have been able to see this alignment and then manipulate it to make it even stronger. Using powerful electron microscopes and a unique atom probe imaging approach at the Environmental Molecular Sciences Laboratory (EMSL), a Department of Energy Office of Science user facility located at PNNL, they were able to peer deep inside the alloy’s nanostructure to see what was happening.
Blacksmithing has now moved from an art form to a more scientific realm. Although the underlying principles are the same, metallurgists are now better able to alter the properties based on the needs of the application. The PNNL team knew if it could see the microstructure at the nano-scale, it could optimize the heat-treating process to tailor the nanostructure and achieve very high strength.
“We found that if you heat-treat it first with a higher temperature before a low temperature heat-treatment step, you could create a titanium alloy 10- to 15-percent stronger than any commercial titanium alloy currently on the market, and that it has roughly double the strength of steel,” says Arun Devaraj, a material scientist at PNNL.
“This alloy is still more expensive than steel, but with its strength-to-cost ratio, it becomes much more affordable with greater potential for lightweight automotive applications,” notes Vineet Joshi a metallurgist at PNNL.
Devaraj and the team used electron microscopy to zoom in to the alloy at the hundreds-of-nanometers scale—about 1,000th the width of an average human hair. Then they zoomed in even further to see how the individual atoms are arranged in 3D by using an atom probe tomography system at EMSL, the Environmental Molecular Sciences Laboratory, a DOE Office of Science User Facility located at PNNL.
The atom probe dislodges just one atom at a time and sends it to a detector. Lighter atoms “fly” to the detector faster, while heavier items arrive later. Each atom type is identified depending on the time it takes to reach the detector, and each atom’s position is identified by the detector. Thus, scientists are able to construct an atomic map of the sample to see where individual atoms are located within the sample.
By using such extensive microscopy methods, researchers discovered that by the optimized heat-treating process, they created micron-sized and nanosized precipitate regions—known as the “alpha phase”—in the beta-phase matrix. Each region has its own high concentrations of certain elements.
“The aluminum and titanium atoms liked to be inside the nanosized alpha-phase precipitates, whereas vanadium and iron preferred to move to the beta matrix phase,” says Devaraj. The atoms are arranged differently in these two areas. Treating the regions at a higher temperature of 1,450° F achieved a unique hierarchical nanostructure.
When the strength was measured by pulling or applying tension and stretching it until it failed, the treated material achieved a 10- to 15-percent increase in strength, which is significant, especially considering the low cost of the production process.
If you take the force you are pulling with and divide it by the area of the material, you get a measure of tensile strength in megapascals. Steel used to produce vehicles has a tensile strength of 800 to 900 megapascals, whereas the 10- to 15-percent increase achieved at PNNL puts Ti185 at nearly 1,700 megapascals, or roughly double the strength of automotive steel while being almost half as light.
The team collaborated with Ankit Srivastava, an assistant professor at Texas A&M’s Material Science and Engineering department to develop a simple mathematical model for explaining how the hierarchical nanostructure can result in the exceptionally high strength. The model, when compared with the microscopy results and processing, led to the discovery of this strongest titanium alloy ever made.
“This pushes the boundary of what we can do with titanium alloys,” says Devaraj. “Now that we understand what’s happening and why this alloy has such high strength, researchers believe they may be able to modify other alloys by intentionally creating microstructures that look like the ones in Ti185.”
For instance, aluminum is a less expensive metal, and if the nanostructure of aluminum alloys can be seen and hierarchically arranged in a similar manner, that would also help the auto industry build lighter vehicles that use less fuel and put out less carbon dioxide that contributes to global warming.
The DOE’s Vehicle Technologies Office—Propulsion Materials Program supported this research using capabilities developed under PNNL’s internally funded Chemical Imaging Initiative.
Pacific Northwest National Laboratory’s picture
For more than 50 years, Pacific Northwest National Laboratory has advanced the frontiers of science and engineering in the service of the United States and the world. PNNL makes fundamental scientific discoveries that illuminate the mysteries of the planet and the universe, and applies scientific expertise to tackle some of the most challenging problems in energy, the environment, and national security.
