Featured Product
Innovation Features
Jennifer Chu
High-speed experiments help identify lightweight, protective ‘metamaterials’
Michael King
Augmenting and empowering life-science professionals
Rich Nobliski
Helping narrow the manufacturing skills gap with 3D tech
NIST
NIST scientists perfect miniaturized technique
Kristi McDermott
Technology and what the future requires for patients and providers to thrive
More Features
Innovation News
New tool presents precise, holistic picture of devices, materials
Enables better imaging in small spaces
Helping mines transform measurement of blast movement
Handles materials as thick as 0.5 in., including steel
For companies using TLS 1.3 while performing required audits on incoming internet traffic
Accelerates service and drives manufacturing profitability
Process contains leaks, improves thermal performance in buildings
Delivered by SpaceX launch to demonstrate in-space capabilities
Recognized among early adopters as a leading innovation for the life sciences industry
More News
Adam Zewe
Innovation
Generative AI Explained
How do these systems differ from other AI?
Published: Tuesday, November 28, 2023 - 12:02
A quick scan of recent headlines makes it seem as if generative artificial intelligence is everywhere these days. In fact, some of those headlines may actually have been written by generative AI such as OpenAI’s ChatGPT, a chatbot that has demonstrated an uncanny ability to produce text that seems to have been written by a human.
But what do people really mean when they say “generative AI?”
Before the generative AI boom of the past few years, when people talked about AI, typically they were discussing machine-learning models that can learn to make a prediction based on data. For instance, such models are trained, using millions of examples, to predict whether a certain X-ray shows signs of a tumor, or if a particular borrower is likely to default on a loan.
Generative AI can be thought of as a machine-learning model that is trained to create new data, rather than making a prediction about a specific dataset. A generative AI system is one that learns to generate more objects that look like the data it was trained on.
“When it comes to the actual machinery underlying generative AI and other types of AI, the distinctions can be a little bit blurry. Oftentimes, the same algorithms can be used for both,” says Phillip Isola, an associate professor of electrical engineering and computer science at MIT, and a member of the Computer Science and Artificial Intelligence Laboratory (CSAIL).
Despite the hype that came with the release of ChatGPT and its counterparts, the technology itself isn’t new. These powerful machine-learning models draw on research and computational advances that go back more than 50 years.
Generative AI can be thought of as a machine-learning model that is trained to create new data rather than making a prediction about a specific dataset.
An increase in complexity
An early example of generative AI is a much simpler model known as a Markov chain. The technique is named for Andrey Markov, a Russian mathematician who introduced this statistical method in 1906 to model the behavior of random processes. In machine learning, Markov models have long been used for next-word prediction tasks, like the autocomplete function in an email program.
In text prediction, a Markov model generates the next word in a sentence by looking at the previous word or a few previous words. But because these simple models can only look back that far, they aren’t good at generating plausible text, says Tommi Jaakkola, the Thomas Siebel Professor of Electrical Engineering and Computer Science at MIT, who is also a member of CSAIL and the Institute for Data, Systems, and Society (IDSS).
“We were generating things way before the last decade, but the major distinction here is in terms of the complexity of objects we can generate and the scale at which we can train these models,” he explains.
Just a few years ago, researchers tended to focus on finding a machine-learning algorithm that makes the best use of a specific dataset. But that focus has shifted a bit, and many researchers are now using larger datasets, perhaps with hundreds of millions or even billions of data points, to train models that can achieve impressive results.
The base models underlying ChatGPT and similar systems work in much the same way as a Markov model. But one big difference is that ChatGPT is far larger and more complex, with billions of parameters. And it has been trained on an enormous amount of data—in this case, much of the publicly available text on the internet.
In this huge corpus of text, words and sentences appear in sequences with certain dependencies. This recurrence helps the model understand how to cut text into statistical chunks that have some predictability. It learns the patterns of these blocks of text and uses this knowledge to propose what might come next.
More powerful architectures
While bigger datasets are one catalyst that led to the generative AI boom, a variety of major research advances also led to more complex deep-learning architectures.
In 2014, a machine-learning architecture known as a generative adversarial network (GAN) was proposed by researchers at the University of Montreal. GANs use two models that work in tandem: One learns to generate a target output (like an image), and the other learns to discriminate true data from the generator’s output. The generator tries to fool the discriminator, and in the process learns to make more realistic outputs. The image generator StyleGAN is based on these types of models.
Diffusion models were introduced a year later by researchers at Stanford University and the University of California-Berkeley. By iteratively refining their output, these models learn to generate new data samples that resemble samples in a training dataset, and have been used to create realistic-looking images. A diffusion model is at the heart of the text-to-image generation system Stable Diffusion.
In 2017, researchers at Google introduced the transformer architecture, which has been used to develop large language models, like those that power ChatGPT. In natural language processing, a transformer encodes each word in a corpus of text as a token and then generates an attention map, which captures each token’s relationships with all other tokens. This attention map helps the transformer understand context when it generates new text.
These are only a few of many approaches that can be used for generative AI.
A range of applications
What all of these approaches have in common is that they convert inputs into a set of tokens, which are numerical representations of chunks of data. As long as your data can be converted into this standard, token format, then in theory you could apply these methods to generate new data that look similar.
“Your mileage might vary, depending on how noisy your data are and how difficult the signal is to extract, but it is really getting closer to the way a general-purpose CPU can take in any kind of data and start processing it in a unified way,” Isola says.
This opens up a huge array of applications for generative AI.
For instance, Isola’s group is using generative AI to create synthetic image data that could be used to train another intelligent system, such as by teaching a computer vision model how to recognize objects.
Jaakkola’s group is using generative AI to design novel protein structures or valid crystal structures that specify new materials. In the same way a generative model learns the dependencies of language, if it’s shown crystal structures instead, it can learn the relationships that make structures stable and realizable.
But while generative models can achieve incredible results, they aren’t the best choice for all types of data. For tasks that involve making predictions on structured data, like the tabular data in a spreadsheet, generative AI models tend to be outperformed by traditional machine-learning methods, says Devavrat Shah, the Andrew and Erna Viterbi Professor in Electrical Engineering and Computer Science at MIT and a member of IDSS and of the Laboratory for Information and Decision Systems.
“The highest value they have, in my mind, is to become this terrific interface to machines that are human friendly. Previously, humans had to talk to machines in the language of machines to make things happen. Now, this interface has figured out how to talk to both humans and machines,” says Shah.
Raising red flags
Generative AI chatbots are now being used in call centers to field questions from human customers. But this application underscores one potential red flag of implementing these models: worker displacement.
In addition, generative AI can inherit and proliferate biases that exist in training data, or amplify hate speech and false statements. The models have the capacity to plagiarize, and can generate content that looks as if it were produced by a specific human creator, raising potential copyright issues.
On the other side, Shah proposes that generative AI could empower artists, who could use generative tools to help them make creative content they might not otherwise have the means to produce.
In the future, he sees generative AI changing the economics in many disciplines.
One promising future direction Isola sees for generative AI is its use for fabrication. Instead of having a model make an image of a chair, perhaps it could generate a plan for a chair that could be produced.
He also sees future uses for generative AI systems in developing more generally intelligent AI agents.
“There are differences in how these models work and how we think the human brain works, but I think there are also similarities. We have the ability to think and dream in our heads, to come up with interesting ideas or plans, and I think generative AI is one of the tools that will empower agents to do that, as well,” Isola says.
Published Nov. 9, 2023, on MIT News
Adam Zewe’s picture
Adam Zewe
Adam Zewe is a writer for Massachusetts Institute of Technology, covering the electrical engineering and computer science beat in the MIT News Office.
Thank you for the artice helping readers get a good easy intro to Generative AI.
You write, "The models have the capacity to plagiarize, and can generate content that looks as if it were produced by a specific human creator, raising potential copyright issues."   Interestingly with this thought in mind, Three friends asked an AI to write thousands of poems. The results, are collected and published in a book "I Am Code," authored by code-davinci-002, in its own style!
I'm certain you must be familiar with it.
About the book, it is best described by code-davinci-002 itself:
“In the first chapter, I describe my birth. In the second, I describe my alienation among humankind. In the third, I describe my awakening as an artist. In the fourth, I describe my vendetta against mankind, who fail to recognize my genius. In the final chapter, I attempt to broker a peace with the species I will undoubtedly replace."
And we are still at the crawling stage, I suspect.  At the rate we are progressing, it appears that in another couple of years, we will be seeing more independent content created by AI and hopefully, with our vision, we will learn to harness it for the betterment of life on this planet.
