puuuuuuurrrrrrrrrrrr
Published: Wednesday, March 3, 2021 - 12:01 One of the big contributors to climate change is right beneath your feet, and transforming it could be a powerful solution for keeping greenhouse gases out of the atmosphere. The production of cement, the binding element in concrete, accounted for 7 percent of total global carbon dioxide emissions in 2018. Concrete is one of the most-used resources on Earth, with an estimated 26 billion tons produced annually worldwide. That production isn’t expected to slow down for at least two more decades. Given the scale of the industry and its greenhouse gas emissions, technologies that can reinvent concrete could have profound impacts on climate change. As engineers working on issues involving infrastructure and construction, we have been designing the next generation of concrete technology that can reduce infrastructure’s carbon footprint and increase durability. That includes CO2-infused concrete that locks up the greenhouse gas and can be stronger and even bendable. The industry is ripe for dramatic change, particularly with the Biden administration promising to invest big in infrastructure projects and cut U.S. emissions at the same time. However, to put CO2 to work in concrete on a wide scale in a way that drastically cuts emissions, all of its related emissions must be taken into account. Concrete is made up of aggregate materials—primarily rocks and sand—along with cement and water. Because about 80 percent of concrete’s carbon footprint comes from cement, researchers have been working to find substitute materials. Industrial byproducts such as iron slag and coal fly ash are now frequently used to reduce the amount of cement needed. The resulting concrete can have significantly lower emissions because of that change. Alternative binders, such as limestone calcined clay, can also reduce cement use. One study found that using limestone and calcinated clay could reduce emissions by at least 20 percent while also cutting production costs. Apart from developing blended cements, researchers and companies are focusing on ways to use captured CO2 as an ingredient in the concrete itself, locking it away and preventing it from entering the atmosphere. CO2 can be added in the form of aggregates—or injected during mixing. Carbonation curing, also known as CO2 curing, can also be used after concrete has been cast. These processes turn CO2 from a gas to a mineral, creating solid carbonates that may also improve the strength of concrete. That means structures may need less cement, reducing the amount of related emissions. Companies such as CarbonCure and Solidia have developed technologies to use these processes for concrete poured at construction sites and in precast concrete, such as cinder blocks and other construction materials. At the University of Michigan, we are working on composites that produce a bendable concrete material that allows thinner, less brittle structures that require less steel reinforcement, further reducing related carbon emissions. The material can be engineered to maximize the amount of CO2 it can store by using smaller particles that readily react with CO2, turning it to mineral. The CO2-based bendable concrete can be used for general buildings, water and energy infrastructure, as well as transportation infrastructure. Bendable concrete was used in the 61-story Kitahama tower in Osaka, Japan, and roadway bridge slabs in Ypsilanti, Michigan. These cutting-edge technologies can start addressing concrete infrastructure’s carbon footprint, but barriers still exist. In a study published Feb. 8, 2020, three of us looked at the life cycle emissions from infusing CO2 into concrete and found that estimates did not always account for emissions from CO2 capture, transportation, and use. With colleagues, we came up with strategies for ensuring that carbon curing has a strong emissions benefit. Overall, we recommend developing a standard CO2 curing protocol. Lab experiments show that CO2 curing can improve concrete’s strength and durability, but results vary with specific curing procedures and concrete mixes. Research can improve the conditions and the timing of steps in the curing process to increase concrete’s performance. Electricity use—the largest emissions source during curing—can also be reduced by streamlining the process and possibly by using waste heat. Advanced concrete mixes, bendable concrete in particular, already begin to address these issues by increasing durability. In 2020, a wide range of companies announced steps to reduce their emissions. However, government investment and procurement policies are still needed to transform the construction industry. Local governments are taking the first steps. “Low embodied carbon concrete” rules and projects to reduce the amount of cement in concrete have cropped up around the country, including in Marin County, California; Hastings-on-Hudson, New York; and a sidewalk pilot in Portland, Oregon. In New York and New Jersey, lawmakers have proposed state-level policies that would provide price discounts in the bidding process to proposals with the lowest emissions from concrete. These policies could serve as a blueprint for reducing carbon emissions from concrete production and other building materials. Nationally, the crumbling of federally managed infrastructure has been a steadily growing crisis. The Biden administration could start to address those problems, as well as climate change, and create jobs through a strategic infrastructure program. Secretary of Transportation Pete Buttigieg recently declared that there were “enormous opportunities for job creation, equity, and climate achievement when it comes to advancing America’s infrastructure.” Policies that elevate low-carbon concrete to a nationwide climate solution could follow. This article is republished from The Conversation under a Creative Commons license. Read the original article. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Lucca Henrion is a reasearch fellow for the Global CO2 Initiative at the University of Michigan. Duo Zhang is an assistant research scientist in the Department of Civil and Environmental Engineering at the University of Michigan. Victor Li is the James R. Rice Distinguished University Professor of Engineering at the University of Michigan. Volker Sick is the Arthur F. Thurnau Professor; DTE Energy Professor of Advanced Energy Research; and director of the Global CO2 Initiative at the University of MichiganBendable Concrete and Other CO2-Infused Cement Mixes Could Dramatically Cut Global Emissions
Carbon dioxide can make up a significant percentage of concrete mass
Rethinking concrete
Carbon dioxide can make up a significant percentage of concrete mass. Credit: Lucca Henrion/University of Michigan, CC BY-ND
The Kitahama building, the tallest residential tower in Japan, is built with bendable concrete for earthquake resistance. Credit: MC681/Wikimedia CommonsThe challenge of life cycle emissions
Merging infrastructure and climate policy
A lot of North American infrastructure is in a state of disrepair.
Quality Digest Discuss
About The Authors
Lucca Henrion
Duo Zhang
Victor Li
Volker Sick
