puuuuuuurrrrrrrrrrrr
Katie Rapp
Published: Tuesday, January 25, 2022 - 12:02 For manufacturers, artificial intelligence (AI) can be a game changer. Greater efficiencies, lower costs, improved quality, and reduced downtime are just some of the potential benefits. This technology isn’t just for large manufacturers. High-value, cost-effective AI solutions are more accessible than many smaller manufacturers realize. In the recent MEP National Network/Modern Machine Shop webinar “Artificial Intelligence in Manufacturing: Real World Success Stories and Lessons Learned,” Andy Carr of South Carolina MEP (SCMEP) and Delta Bravo founder and CEO Rick Oppedisano discussed AI solutions that work best for small and medium-sized manufacturers (SMMs). Delta Bravo is a third-party vendor that works with SCMEP manufacturing clients on AI solutions to meet their needs. In the webinar, Rick described AI use cases featuring several manufacturers he has worked with, including Precision Global, Metromont, Rolls-Royce, JTEKT, and Elkem Silicones. Since 2017, Delta Bravo has worked on about 90 projects and has learned what works best and produces significant return on investment (ROI), especially for smaller manufacturers. AI projects improved equipment uptime, increased quality and throughput, and reduced scrap. With the healthier bottom lines and increased profits came lessons learned. Rick identified key drivers for successful AI implementation, potential pitfalls and best practices, and shared some pro tips. People often use the terms “AI” and “machine learning” interchangeably, but they’re two very different things. Machine learning puts data from different sources together and helps you understand how the data is acting, why, and which data correlate with other data. It helps you solve a particular problem by taking historic evidence in the data to tell you the probabilities between various choices, and which choice clearly worked better in the past. It tells you the relevance of all this, the probabilities of certain outcomes, and the future likelihood of these outcomes. AI is what takes action on a recommendation supplied by machine learning. To use a hot-stove analogy, when you put your hand near a hot stove, your brain tells you from past experience and from the tingling in your fingers what could possibly happen and what you should do. That’s like machine learning. AI is the technical ability to pull your hand back before you get burned. Using AI in a manufacturing context means using data to make actionable decisions faster and more accurately than a human can. There are two specific areas where this makes a lot of sense: for forecasting and for understanding anomalies or outliers. There are parts of the manufacturing process where forecasting can drive value. If you have enough historic data and context about the decisions and process around the data, there’s a good chance you can develop predictions. Why do the same inputs on the same machines sometimes have different outcomes? Is there an occasional manufacturing scenario that you want to understand? The data off one machine can be overwhelming to a human analyst, so that’s where AI can help. In addition, manufacturing systems are holistic, and one metric in part of the process relates to another part of the same process. If you’re looking only at one area, how do you know what’s going on in another? AI can offer the solution. AI can create a significant financial impact in five areas: 1. Predictive maintenance. By taking historic data from maintenance logs, you can predict how a machine will behave under a future payload, as well as whether you’ll need to fix it, when, why, and how—based on what fixed that problem in the past. This can reduce downtime significantly. There’s a lot of skepticism about introducing AI solutions in manufacturing and whether the investment is justified. Successful AI implementation boils down to three P’s: problem, persona, process. You must carefully define a suitable problem for AI to solve. You need the right people involved, including leadership, operations, IT/tech, digital transformation, and finance people. They each play a key role in successfully adopting AI. And you need a process approach that identifies the right way to tackle the problem with AI. You must understand whether the data to solve the problem exist. How do you know if your company is ready to try implementing AI? Think of it as a three-legged stool. Without all three of these in place, the implementation won’t succeed, and your company isn’t ready for AI: 1. Driven from the top. If there’s no corporate initiative and priority from the top to use data to make the business better, it won’t work. Finally, here are some high-level pro tips for successfully implementing AI that Delta Bravo has learned from experience. Designate a center of excellence Medium-sized manufacturers with multiple locations should pick one as their center of excellence for an AI pilot. Deploy AI at a single site with a single line, and then scale out to two or three lines before expanding to more sites. Name a practice lead, one person in charge of communicating and working through this effort with your vendor. It can’t be this person’s third job. Know your unit economics When deploying AI, everyone is talking about the cloud because it’s an easy way to access computing resources. These provide virtual equipment by combining CPUs, memory, and disks to create virtual machines with minimal maintenance. What the cloud providers don’t tell you is the way they make money. They store your data pretty cheaply, but when you start using computing resources, it becomes a lot more expensive. You want the ability to scale across different cloud providers or storage solutions, whichever is most cost effective. Be wary of technical lock-in It’s painful and expensive to migrate once you have all your data in a single cloud provider. Be aware that big tech is easy to get into but hard to get out of. Avoid going all in on any one provider. No one size fits all There are vendors who promise a prebuilt, predictive maintenance solution—and all you do is plug your data in. Don’t believe it. The solution you need is based on understanding your process and tweaking based on your priorities. A prebuilt model is no silver bullet. You’ll end up spending more and going backward. Huge opportunity for progress AI offers more than coming up with a fancy machine-learning model and figuring out how to use it. This capability can make everyone in the organization smarter, not just the operations person. For example, machine learning can automate spreadsheet processes, visualizing data on an analytics screen where it’s refreshed daily and you can access it anytime. To be competitive in the future, SMMs must begin implementing advanced manufacturing technologies today. Many original equipment manufacturers (OEMs) are pushing requirements down their supply chain, and the smaller manufacturers are in a bind. You have this pressure but don’t have the resources to implement the technologies. If you’re overwhelmed, know that you’re not alone. Contact your local MEP center for help. Between the MEP centers in every state and Puerto Rico, and our 1,400 trusted advisors, the MEP National Network offers assistance within a two-hour drive of every U.S. manufacturer. When you call your local MEP center, you’ll speak to seasoned manufacturing professionals who understand SMMs. Some have owned a manufacturing company, so they understand the language you speak and the challenges you face. Through hands-on technical assistance as well as connecting you with grants, awards, and other funding sources, network experts can help mitigate the risk of adopting AI and other advanced technologies. MEP-center staff can facilitate introductions to trusted subject matter experts. For areas like AI, where not all MEP centers have the expertise on staff, they can locate and vet potential third-party service providers. Center staff help ensure the third-party experts have a track record of implementing successful, impactful solutions and that they’re comfortable working with smaller firms. Let the MEP National Network be your resource to help your company move forward faster. First published Jan 7, 2022, on NIST’s Manufacturing Innovation Blog. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Katie Rapp is a writer and editor for NIST’s Manufacturing Extension Partnership, where she helps NIST MEP staff use plain language so their readers can understand what they write the first time they read it.AI for Small and Medium-Sized Companies
Benefits, tips, and lessons learned
Artificial intelligence and machine learning
Why adopt AI?
2. Predictive quality. Predicting and reducing failures can yield significant cost savings.
3. Scrap reduction. Using metrics to predict behavior across product specifications can minimize scrap and maximize product quality.
4. Increasing yield/throughput. Predicting if and when a machine or process will no longer meet given specifications enables you to proactively do what’s needed to bring it back into specification, reducing quality passes.
5. Demand and inventory forecasting. With a thorough understanding of plant operations and the data behind production, it’s possible to forecast the demand and movement of critical parts, resulting in significant inventory savings.Best practices and potential pitfalls
With any new technology rollout, it makes sense to start with a pilot, such as piloting AI on one production line. You create an iteration, work through any issues that come up, and then extend the pilot to different machines or different lines. By scaling the technology incrementally, it can be cost effective and not break the bank for smaller manufacturers. Think of focusing on ROI in the same way a house is built. A house isn’t made just from digging a basement but from everything that’s built on top of the foundation. Similarly, don’t expect to build an AI foundation and see an immediate return.
2. Invested in data collection. If your company hasn’t invested in collecting data in a consistent way, where people are saving it and care about it, it won’t work.
3. Find the pain, find the gain. Can you quantify the specific financial impact of problems like unplanned downtime, scrap, or throughput? If not, it won’t work.Pro tips
Contact your local MEP center to get started
Quality Digest Discuss
Katie Rapp
