Featured Product
Health Care Features
Etienne Nichols
How to give yourself a little more space when things happen
Chris Bush
Penalties for noncompliance can be steep, so it’s essential to understand what’s required
Jennifer Chu
Findings point to faster way to find bacteria in food, water, and clinical samples
NIST
Smaller, less expensive, and portable MRI systems promise to expand healthcare delivery
Lindsey Walker
A CMMS provides better asset management, streamlined risk assessments, and improved emergency preparedness
More Features
Health Care News
Showcasing the latest in digital transformation for validation professionals in life sciences
An expansion of its medical-device cybersecurity solution as independent services to all health systems
Purchase combines goals and complementary capabilities
Better compliance, outbreak forecasting, and prediction of pathogens such as listeria or salmonella
Links ZEISS research and capabilities in automated, high-resolution 3D imaging and analysis
Creates one of the most comprehensive regulatory SaaS platforms for the industry
Resistant to high-pressure environments, and their 3/8-in. diameter size fits tight spaces
Easy, reliable leak testing with methylene blue
New medical product from Canon’s Video Sensing Division
More News
Health Care
Tracking Covid-19: Update
New projections as of April 12, 2020
Published: Monday, April 13, 2020 - 12:03
This article is an update to “Tracking Covid-19” that Al Pfadt, Kathryn Whyte, and I wrote last week. In that article we summarized what is known about Covid-19, what has already happened, and what is to be expected based on the analysis of the data and the epidemiological models.
Over the past week the curve of Covid-19 infections in the United States has slightly flattened. Here are updated graphs of the actual data and new projections for what we can expect in the next few weeks.
Figure 1 shows the number of confirmed cases of Covid-19 in the United States as of 7 a.m. each day. These are the values posted by the European CDC at noon London time, and so they are slightly smaller than some other values that are reported later each day.
Figure 1: Number of confirmed Covid-19 cases in the United States
While the number of confirmed cases doubled every two to three days during the first four weeks of March, the counts are no longer growing at that rate. The curve in figure 2 has flattened somewhat. Fitting a line to the last few points by eye and extending it forward we can see that the United States is on track to hit one million confirmed cases sometime around April 21.
Figure 2:  Confirmed Covid-19 cases in the United States
It is important to note that, unlike so many others, this projection is not based on some complex mathematical model. Mathematical models always require assumptions, which will generally reflect the author’s point of view. Rather, these projections are simply the actual current data extended into the future. If we are able to further flatten the curve we should find the future values falling below the projections. If the future values fall above the projections then our efforts to mitigate the infection are faltering. These graphs are  nothing more or less than our report cards.
Figure 3 below contains the data for the number of Covid-19 deaths in the United States.
Figure 3: Number of Covid-19 deaths in United States
While there has been a slight flattening of this curve over the past week, the deaths are still  increasing by 11.6 percent each day. This gives a doubling time of about every 5 days (compare 4/12 and 4/7). At this rate we have the potential of reaching a total of 100,000 deaths by April 25, as may be seen from the straight line projection in figure 4.
However, deaths lag behind the confirmed cases, and the confirmed cases curve has flattened. They are increasing about 7 percent each day which gives a doubling time of about 10 days. So, a more conservative projection for the number of deaths can be had by using the curved projection arrow where the deaths taper off to a daily increase of 7 percent. Here we project a total of 50,000 deaths by April 25. Hopefully the number of deaths will fall short of this projection.
Figure 4:  Covid-19 fatalities in the United States
For more information about these graphs and Covid-19, see “Tracking Covid-19” in the April 6 edition of Quality Digest. Readers are encouraged to print out this update and plot the daily numbers on each graph for themselves. Hopefully they will fall below the projections.
You can also download this Excel spreadsheet, enter the daily numbers yourself, and have a similar graph automatically updated for you.
Also, this simple Excel spread sheet should help show the difference between a linear vs. semi-log chart for showing exponential data.
About The Authors
Donald J. Wheeler’s picture
Dr. Wheeler is a fellow of both the American Statistical Association and the American Society for Quality who has taught more than 1,000 seminars in 17 countries on six continents. He welcomes your questions; you can contact him at djwheeler@spcpress.com.
Al Pfadt’s picture
Al Pfadt
Dr. Al Pfadt is a retired research scientist who learned to apply the principles of Statistical Process Control in healthcare through his affiliation with Dr. Donald Wheeler, which began nearly 30 years ago. They have published numerous articles describing those applications in a variety of settings. Their most recent article in Oncogen illustrated how to use both Process Behavior and Celeration charts to continually monitor and modify dynamic biological systems that are showing the same type of exponential growth that the Covid-19 virus displays.
Kathryn J. Whyte’s picture
Kathryn J. Whyte
Dr. Kathryn Whyte is a clinically trained nutritional and physical activity interventionist with an extensive background in dietary and physical activity assessment, prescription and data analysis.  Dr. Whyte’s published research and research interests relate to questions involving diet and exercise quality, human phenotyping, and implications for metabolic health across the lifespan.  She is currently an NIH funded post doctoral fellow at Columbia University Medical Center’s New York Obesity Nutrition Research Center.
Semilog charts simple example
Several of our readers have had questions about a semilog chart and why it is useful for showing changes in rate.
This simple Excel spread sheet should help show the difference between a linear vs a semilog chart for showing exponential data.
Limitations of using aggregated data
I am amplifying the comments Don made in reply to questions about data from NYState.
Any time data is combined from multiple sources it becomes more difficult to draw conclusions that apply to all cases.
Even in our original article which looked at the spread of the virus in a particular community ( New Rochelle) the original spread of the virus within the closely knit Orthodox Jewish community where the first few cases were transmitted, subsequent cases were undoubtedly due to transmission from other communities.
Likewise, some of the small rural states which currently are contributing small numbers to the national total may find themselves in the unenviable position of being a hot spot.
An article in the NYTimes this week described how individuals from a company with offices all over the world served as a " Petrie dish" that spread infections each person at that meeting brought with them from other countries back to the local communities each returned to when the meeting was over. The outbreak in Tennessee that Don referred to has been traced to one person who attended that meeting.
Since national trends are the focus of much of the current discussion we decided to clarify confusion about those data first. Our methods can be applied to any level of analysis to address other concerns. Hopefully, the tools we have provided in our follow up article will help others do just that.
Extending Data
How exctly do you "extend data" without a model?  Even if you don't assume a mathematical model, you still have to decide how to extrapolate, right?  Am I missing something?
Drawing the Arrows
Stephen,  the semi-log plot turns exponential curves into straight lines.  When the most recent points are reasonably colinear, we can use those points to define a line.  If there is no change in the rate of the exponential growth, then the projection of that line into the future will provide reasonable predictions.  So, you could say the model is the process behavior in the recent past.  In the case of the curved projection in Figure 4, I explained that I transitioned from the current growth rate of the deaths to the growth rate shown by the confirmed cases.  (Looking back at the past, the deaths have had a growth rate that matched the growth rate of the confirmed cases about 5 to 7 days earlier.)  So here I used the demonstrated relationship betwen the two related curves to create a non-linear projection.  (Since then the data have fallen just under the curved projection.)
So there is no explicit model, just the implicit model of letting the recent past predict the near future.  Clearly, in a dynamic situation such as an epidemic, we do not take these "predictions" as anything other than as a guide for deciding if we are getting better or worse.  They define a context to use in interpreting each new value as it comes along.
Effect of Covid-19 Testing Constraint
Has anyone looked at how the number of tests administered vs. the number of people infected might be "flattening the curve?" I heard a report this morning that labs are sitting idle because many hospitals don't have equipment to take sufficient samples. If the number of tests administered as a proportion of the overall cases is going down (relatively flat or declining), this could be artificially flattening the curve.
For that matter, several factors other than actual changes in infection rate could be causing this flattening. The number of patients that can be seen in a day with the resources available, the number of tests that can be obtained or processed, and even changes in the screening criteria could each have this effect singly or in combination.
It boils down to the fundamental question “how robust is the measurement system that is being used?
Don't have equipment for samples?
In response to
"I heard a report this morning that labs are sitting idle because many hospitals don't have equipment to take sufficient samples."
Due to recent travel across the US and having symptoms of shortness of breath and severe cough, my primary doctor decided to test me for COVID-19.  First, I was tested for Strep throat and traditional flu with a swab of my tongue and nostrils.  Then came the very uncomfortable COVID-19 test.  It was a swab to the very back of each nostril, which was mailed out to a lab.  It came back in a week, negative, fortunately.
So, the only "equipment" needed is a Q-Tip type swab, followed by lab analysis of the swab.
Allen
Douglas
We have to consider the number of confirmed cases as a lower bound.  This is the reason for the emphasis on the word "confirmed."  In the article on April 6 we noted that when they had a test and tested people repatriated from China they found that 40% to 50% of those with Covid-19 had not been identified due to no symptoms or low symptoms.  So, if a person has Covid-19 but shows no symptoms, they can just go around infecting people without ever feeling bad enough to ask for a test.  So, yes, these numbers are incomplete.  On the other hand, the nature of this pandemic does not lend itself to false flattenings.  Without interventions each case will generate an average of 2.5 new cases, which is exponential growth.
If we have the ability to
If we have the ability to confirm them. That I think, is the question here. If there are only 100,000 tests conducted a day, and the pre-screening has a 70% false positive rate, we would expect to have about 30,000 new confirmed cases per day. As the total number of cases goes up, this 30,000 new-confirmed cases becomes a smaller and smaller proportion of the total. I am reminded of an anecdote (fictional I am sure) that a friend relayed to me:
 A small third world country was recently praised for its very low rate of only 35 confirmed cases. When asked how many people had been tested, the reply was "38."
COVID-19 Tracking
Have you considered using the Z-Score statistic to track improvement by countries and states to show their relative position on the bell curve. I have used the Z-Score of %CLOSED (also 1-% ACTIVE) according to daily W.H.O. reporting. Most countries have Z-Scores less than 0 (50% CLOSED) but China remains at slightly above 2.0. Japan reached Z= -0.52 on 3/27 and retreated steadily to Z=-1.16 on 4/12, as predictive of their recent national emergency declaration. Other countries have shown linear trends with a slope of 0.01 to 0.07 points of Z-Score improvement per day. The Z=Score of CLOSED Cases is a lagging indicator by 10 to 20 days as the Recovery or Death needs time to determine. The goal is to get ahead of the ACTIVE Casess and get on the downside of the Bell Curve. If you want more information, I can send you an article that I posted on LinkedIn or you can contact me.
Reply for DONFWILSON
This approach is full of so many incorrect and inappropriate assumptions that the resulting "scores" are, and will always be, meaningless.  Taiwan has had three waves of infection.  Have you ever seen a three humped normal?  The world is in the middle of its second wave of infection.  Before we start computing all sorts of meaningless numbers we need to stop and listen to the voice of the process and interpret that voice in the context of what it represents.
COVID-19 Tracking
Thanks, Donald
I have always respected your opinion. I also appreciate your leading me to Taiwan's experience. I have been downloading from the W.H.O. database daily since 3/18/2020.
With data from 212 countries and 55 US States and territories, I haven't looked at every trend. The Z-Score for Taiwan shows Z= -0.67 on 3/18, dipping steadily to a Z =-1.21 on 3/27 and increasing to -0.35 on 4/14. Most countries show a steady linear improvement, with Z-Scores less than 0, but Taiwan's graph is a pretty clean parabola. Another country that appears different is Japan, with a steady improvement from Z= -0.70 on 3/18 to -0.52 on 3/27 and a steady decrease to -1.16 on 4/14. We first recognized the trend on 4/5 after 8 consecutive decreases since 3/28. Coincidently, Japan declared a national emergency on that day, putting sanctions back in place.
The Z-Score method using %Closed Cases is a lagging indicator by 10-20 days, but does serve as a metric for measuring improvement. It doesn't predict new cases or deaths, but it does show where actions and resources have been effective overall to reduce new cases or countries have taken actions necessary to close cases. While there are many variables that affect all measures of the process, including actions to mitigate transmission, numbers of tests taken, measurement error in reporting. new actions for cures and prevention, the Z-Score is a decent metric to help determine when to relax sanctions and identify new eruptions of the virus.
If you want more data or explanation of the method used, or graphs just let me know. I did post the thinking on LinkedIn on 4/5/2020.
Covid - 19
The percent increase each day from the previous day gives a very clear indication of how this is slowing. Around March 5 & 6, we had about a 45% increase each day over the previous. Currently we are getting about a 5% increase. My projection estimates 4/24 as the day that we would hit 1,000,000 cases, but each day the proportion of increase is getting smaller, so even this estimate may be overly pessimistic. I have a nice chart of this data that I can not post here, but it shows that the rate of increase is slowing each day as a linear function with line formula y = -0.0101x + 444.93.
I should mention that this data is end-of-day from the Washington Post. I will run the same analysis with the data above.
Different data, different estimate y = -0.009x + 393.82 but still showing a steady decline.
Reply for DouglasB
Yes, we can see a decline in the day-to-day rates as the curve flattens out.  The advantage of the semi-log plot is that it is easier to see a bend in a straight line than to see a slight difference in an exponential curve.  When computing the current doubling time I do it as follows: I divide each day's value by the previous day's value to get a daily rate.  I average the last three daily rates to get a smoothed current rate.  When I divide the log of 2.0 by the log of the smoothed current rate the result is the doubling time.  This does not assume anything about the future, but merely characterizes what is happening currently.  The future data will confirm or tell of a change as it happens.
Track Covid-19 in New York
This is a great way to get a glimpse of what may occur in the near future.  My only concern is that the population data are so heavily influence by New York data that it's kind of a misrepresentation.  Since the bulk of the data is contributed by New York, it might be good to separate that data out and see what the rest of the country is doing at the same time.  I've been tracking the data presented by Time Magazine's website.  Here you can select any state in the union to see how they are doing individually.
Paul Carroll
State by state tracking
Yes, Paul, the same could be applied within states as well.  I have been tracking the Tennessee numbers, and our current doubling time is about 11 days.  But half of the cases in Tennessee are in the greater Nashville area, one-fourth are in Memphis, and the rest are scattered around the state.  My home town of Knoxville has about 5% of the state total.
