Our landlords thank you.
Jennifer Mallow
Published: Monday, September 21, 2020 - 11:02 Covid-19 has led to a boom in telehealth, with some healthcare facilities seeing an increase in its use by as much as 8,000 percent. This shift happened quickly and unexpectedly, and has left many people asking whether telehealth is really as good as in-person care. During the last decade, I’ve studied telehealth as a Ph.D. researcher while using it as a registered nurse and advanced-practice nurse. Telehealth involves the use of phone, video, internet, and technology to perform healthcare, and when done right, it can be just as effective as in-person healthcare. But as many patients and healthcare professionals switch to telehealth for the first time, there will inevitably be a learning curve as people adapt to this new system. So how does a patient or provider make sure they are using telehealth in the right way? The answer to that question depends on the technology available, the patient’s medical situation, and the risks of going—or not going—to a healthcare office. There are three main types of telehealth: synchronous, asynchronous, and remote monitoring. Knowing when to use each one—and having the right technology on hand—is critical to using telehealth wisely. Synchronous telehealth is a live, two-way interaction, usually over video or phone. Healthcare providers generally prefer video conferencing rather than phone calls because aside from tasks that require physical touch, nearly anything that can be done in person can be done over video. But some things, like taking blood samples, for example, simply can’t be done over video. Many of the limitations of video conferencing can be overcome with the second telehealth approach, remote patient monitoring. Patients can use devices at home to get objective data that are automatically uploaded to healthcare providers. Devices exist to measure blood pressure, temperature, heart rhythms, and many other aspects of health. These devices are great for getting reliable data that can show trends over time. Researchers have shown that remote-monitoring approaches are as effective as—and in some cases better than—in-person care for many chronic conditions. Some remaining gaps can be filled with the third type, asynchronous telehealth. Patients and providers can use the internet to answer questions, describe symptoms, refill prescriptions, make appointments, and for other general communication. Unfortunately, not every provider or patient has the technology or the experience to use live video conferencing or remote monitoring equipment. But even having all the available telehealth technology does not mean that telehealth can solve every problem. Generally, telehealth is right for patients who have ongoing conditions or who need an initial evaluation of a sudden illness. Because telehealth makes it easier to have frequent check-ins compared to in-person care, managing ongoing care for chronic illnesses like diabetes, heart disease, and lung disease can be as safe as or better than in-person care. Research has shown that telehealth can also be used effectively to diagnose and even treat new and short-term health issues as well. The tricky part is knowing which situations can be dealt with remotely. Imagine you took a fall and want to get medical advice to make sure you didn’t break your arm. If you were to go to a hospital or clinic, almost always the first healthcare professional you’d see would be a primary care generalist, like me. That person will, if possible, diagnose the problem and give you basic medical advice: “You’ve got a large bruise, but nothing appears to be broken. Just rest, put some ice on it, and take a pain reliever.” If I look at your arm and think you need more involved care, I would recommend the next steps you should take: “Your arm looks like it might be fractured. Let’s order you an X-ray.” This first interaction can easily be done from home using telehealth. If a patient needs further care, she would simply leave home to get that care after meeting with me via video. If she doesn’t need further care, then telehealth just saved a lot of time and hassle for the patient. Research has shown that using telehealth for things like minor injuries, stomach pains, and nausea provides the same level of care as in-person medicine and reduces unnecessary ambulance rides and hospital visits. Some research has shown that telehealth is not as effective as in-person care at diagnosing the causes of sore throats and respiratory infections. Especially now during the coronavirus pandemic, in-person care might be necessary if you are having respiratory issues. And finally, for obviously life-threatening situations like severe bleeding, chest pain, or shortness of breath, patients should still go to hospitals and emergency rooms. With the right technology and in the right situations, telehealth is an incredibly effective tool. But the question of when to use telehealth must also take into account the risk and burden of getting care. Covid-19 increases the risks of in-person care, so while you should obviously still go to a hospital if you think you may be having a heart attack, right now it might be better to have a telehealth consultation about acne—even if you might prefer an in-person appointment. Burden is another thing to consider. Time off work, travel, wait times, and the many other inconveniences that go along with an in-person visit aren’t necessary simply to get refills for ongoing medication. But if a provider needs to draw a patient’s blood to monitor the safety or effectiveness of a prescription medicine, the burden of an in-person visit to the lab is likely worth the increased risk. Of course, not all healthcare can be done by telehealth, but a lot can, and research shows that in many cases, it’s just as good as in-person care. As the pandemic continues and other problems need addressing, think about the right telehealth fit for you, and talk to your healthcare team about the services offered, your risks, and your preferences. You might find that there are far fewer waiting rooms in your future. This article is republished from The Conversation under a Creative Commons license. Read the original article. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Jennifer Mallow is an associate professor at West Virginia University School of Nursing. Her primary research interest is the use and development of technology to improve access and outcomes for persons with multiple chronic conditions, living in rural and under served areas. Is Telehealth As Good As In-Person Care?
A telehealth researcher explains how to get the most out of remote healthcare
Telehealth technologies
Ongoing care and first evaluations
Balancing risk
Quality Digest Discuss
Jennifer Mallow
