Featured Product
Health Care Features
Etienne Nichols
How to give yourself a little more space when things happen
Chris Bush
Penalties for noncompliance can be steep, so it’s essential to understand what’s required
Jennifer Chu
Findings point to faster way to find bacteria in food, water, and clinical samples
NIST
Smaller, less expensive, and portable MRI systems promise to expand healthcare delivery
Lindsey Walker
A CMMS provides better asset management, streamlined risk assessments, and improved emergency preparedness
More Features
Health Care News
Showcasing the latest in digital transformation for validation professionals in life sciences
An expansion of its medical-device cybersecurity solution as independent services to all health systems
Purchase combines goals and complementary capabilities
Better compliance, outbreak forecasting, and prediction of pathogens such as listeria or salmonella
Links ZEISS research and capabilities in automated, high-resolution 3D imaging and analysis
Creates one of the most comprehensive regulatory SaaS platforms for the industry
Resistant to high-pressure environments, and their 3/8-in. diameter size fits tight spaces
Easy, reliable leak testing with methylene blue
New medical product from Canon’s Video Sensing Division
More News
Mark Graban
Health Care
Takt Time for Apple's App Store and for Health Care
The juggling act of time and demand
Published: Tuesday, September 1, 2009 - 15:00
A couple of Sundays ago, I read this New York Times article about Apple's "App Store" for the iPhone and iPod Touch (I've been a pretty happy iPhone user for the past three months after switching over from BlackBerry).
I'm going to try to use this example to teach about two concepts that can be used in virtually any process—takt time and cycle time—including some questions for health care.
Some details of Apple operations came out through filings made in response to the controversy over Apple not carrying the "Google Voice" app and a Federal Communications Commission investigation. The article unveils:
"For example, Apple receives 8,500 new applications and updates to applications each week. The company employs a team of 40 full-time trained reviewers, and each application is independently evaluated by two separate reviewers before getting a green light."
Takt is a lean concept that comes from a German word. If you're a musician, you recognize the "tt = 120" designation to mean that "takt time is 120 beats per minute." You can think of takt as the tempo of a process. And the definition starts with the customer—what is the pace of customer demand?
Starting with takt in mind (again, focusing on the customer) is the first step in making sure that your processes can meet your customer's needs. This concept can be applied in automobile manufacturing (what's the rate of customer demand for Priuses?) or even in medical settings (what's the demand for "blood draws" to collect testing specimens from patients?)
The basic formula is this:
Takt = Available Time/Demand
Using the data from the article, I am assuming the following:
  • I will assume the 40 FTEs work a full day (7.5 hours of work after lunch and breaks)
  • If they have 8,500 apps each week and there are two independent reviews, that demand is actually 17,000 inspections per week = 3,400 inspections per day assuming a five-day work week.
The numerator of the equation can be expressed in minutes:
7.5 hours x 3,600 (number of seconds in one hour) = 27,000 seconds.
For the moment, the fact that we have 40 FTEs is irrelevant, because we are calculating the demand rate (takt time).
So we calculate takt as:
Takt = 7.5 x 3,600/3,400
= 7.94 sec.
7.94 seconds? How in the world can they do an inspection of an application that quickly?
Well, they don't have to work that quickly. I'll explain.
Cycle time is a term that means how long it takes to do a repetitive job each time. If you are writing three blog posts in a row, the cycle time is the time required to write one of them. (More on the term "cycle time" here).
For any process to meet demand, the total cycle time must be faster than the takt time. This means a smaller number: a cycle time of 10 minutes is OK if takt is 15 minutes, for example.
If Apple has 40 FTEs working on these application inspections, then each doesn't have to get the work done in 7.94 seconds. Each one can take 317.6 seconds, at most, as shown below. If they take longer, then the work won't get done and inventory of un-inspected (and un-approved) applications will grow forever.
40 x 7.94 =
= 317.6 sec
= 5.29 min.
Five minutes doesn't seem very long to inspect an application, does it? Maybe a lot of them are just updates that don't take as long to inspect?
In the physician example, if takt time = 5 minutes (a patient arrives every five minutes), and one physician requires a cycle time of 10 minutes, then you need 2 physicians to keep up with customer demand. This keeps takt and cycle in balance. We can get our work done.
Do you use an approach like this? One potential problem is that this approach assumes customer demand is equal and constant across a time period . We know that's not typically true in health care. If you have, on average, a patient arriving every five minutes, but four arrive at once, you are bound to have some patient waiting. That's one reason why it is important to "level load" demand where you can (a subject for another post, I guess).
In the laboratory testing examples, if we have to draw blood from 180 patients for testing before morning rounds, and we have three hours to get this done (10,800 seconds), then the takt time for collecting specimens (and for testing specimens) is 60 seconds. This is an example where we can level out the work over the three hours (we don't have patients arriving randomly).
If drawing blood from one patient (and walking to the next) takes, on average, five minutes, how many phlebotomists do you need at minimum?
I haven't seen too many labs (or other health care settings) use math like this to even estimate staffing levels. Have you? Is this a better method than using benchmarks or budgets? Is this method practical, even given some real world variation? Even if you say "no," does the explanation make sense?
Mark Graban’s picture
Mark Graban
Mark Graban is an author, educator, podcaster, and speaker in lean and continuous improvement strategies through his company Constancy Inc. He is a senior advisor to the technology company KaiNexus, the founder of LeanBlog.org, and the author of Lean Hospitals, Healthcare Kaizen (with Joseph E. Swartz), both recipients of the Shingo Publication Award. Mark’s most recent books are Measures of Success and The Mistakes That Make Us: Cultivating a Culture of Learning and Innovation.
