Featured Product
FDA Compliance Features
Jennifer Chu
Findings point to faster way to find bacteria in food, water, and clinical samples
Matthew M. Lowe
Take this opportunity to prepare for the future
Etienne Nichols
QMSR for medical device companies
Kari Miller
CAPA systems require continuous management, effectiveness checks, and support
Etienne Nichols
The answers will reveal the truth about your product and get it to market faster
More Features
FDA Compliance News
Facilitates quick sanitary compliance and production changeover
Creates one of the most comprehensive regulatory SaaS platforms for the industry
Company’s first funding round will be used to accelerate product development for its QMS and MES SaaS offerings
Showcasing tech, solutions, and services at Gulfood Manufacturing 2022
Easy, reliable leak testing with methylene blue
Now is not the time to skip critical factory audits and supply chain assessments
Google Docs collaboration, more efficient management of quality deviations
Delivers time, cost, and efficiency savings while streamlining compliance activity
First trial module of learning tool focuses on ISO 9001 and is available now
More News
FDA Compliance
Maintaining Quality Assurance in Pharmaceutical Packaging
Published: Tuesday, November 15, 2022 - 13:01
(Wittgas: Witten, Germany) -- Because leaky pharmaceutical packaging can endanger the shelf life and efficacy of packaged medicines, leak testing is a must. This can be easily and reliably done using Witt’s methylene blue test with the Leak-Master Easy.
As particularly sensitive products, medicines require high-quality packaging. Even the smallest leaks, invisible to the naked eye, can render the protective barrier of blister packs ineffective. Oxygen, moisture, and microorganisms can penetrate and make the medicines unusable.
To test the integrity and tightness of blister packs in particular, the packs are placed in a container with an ethanol-based test liquid containing methylene blue as a dye. The blue dye creeps into leaking packages and colors the contents a striking blue, making defective seals or blister cavities clearly identifiable. The method is suitable for detecting leaks with a size of about 10–20 µm.
Witt’s Leak-Master Easy makes the proven methylene blue test particularly fast, reliable, and user-friendly: A vacuum is pulled above the water in the test chamber. The negative pressure first extracts the existing gas volume from leaking blisters. As soon as the negative pressure in the test chamber is equalized again, a negative pressure prevails in the leaking blister, and methylene blue liquid is drawn in, quickly making leakage visible.
The Leak-Master Easy is also low-maintenance with minimal operating costs. Depending on the version, the vacuum can be generated by compressed air or by an electric vacuum pump. Due to the intuitive operation, no specially trained personnel is required. The robust acrylic housing is hygienic and easy to clean; test liquid can simply be drained through a valve at the base.
With the optional Plus control unit, testing is even easier and more standardized. The tester places the product in the chamber and starts a stored test program. The required vacuum is pulled automatically and maintained for the desired test duration. All tests are digitally documented, and the results can be exported.
The Leak-Master Easy is available in seven different chamber sizes. For more information, visit wittgas.com.
Quality Digest’s picture
For 40 years Quality Digest has been the go-to source for all things quality. Our newsletter, Quality Digest, shares expert commentary and relevant industry resources to assist our readers in their quest for continuous improvement. Our website includes every column and article from the newsletter since May 2009 as well as back issues of Quality Digest magazine to August 1995. We are committed to promoting a view wherein quality is not a niche, but an integral part of every phase of manufacturing and services.
