Featured Product
Customer Care Features
Leah Chan Grinvald
Independent repair shops are fighting for access to vehicles’ increasingly sophisticated data
Gad Allon
Aligning timing, leadership, and strategy is complicated
ISO
Delivering quality to the health industry
Mike Figliuolo
Globalization is an unstoppable trend, so why not take advantage of it?
More Features
Customer Care News
A tool to help detect sinister email
Developing tools to measure and improve trustworthiness
Manufacturers embrace quality management to improve operations, minimize risk
Scaling operations to reduce plastic waste in oceans
Survey shows 85% of top performers rely on it to achieve business objectives
Educational offerings available in Santa Clara in December 2023
Precision cutting tools maker gains visibility and process management across product life cycles
A Heart for Science initiative brings STEM to young people
More News
Del Williams
Customer Care
Cablevey Mobile ‘Smart Cart’ Automates Food Conveyor CIP
Facilitates quick sanitary compliance and production changeover
Published: Wednesday, July 26, 2023 - 11:00
(Cablevey: Oskaloosa, IA) -- To promote food safety and sanitary compliance, processors increasingly seek the ability to clean-in-place (CIP), an automated method of cleaning the interior surfaces of tubular drag conveyors without disassembly. Now, with the advent of mobile tools like an innovative “smart cart” that quick-connects to any tubular conveyor and enables simple, customizable “single-button cleaning recipes,” CIP is becoming easier, faster, less labor-intensive, more repeatable, and almost fully automated.
Tubular drag conveyor systems gently move product through a sealed, enclosed tube using a drag cable and circular discs pulled through on a loop, making them ideal for delicate items. In a wet CIP process, the system is flooded with water, flushed, rinsed, cleansed, and sanitized. The process thoroughly flushes any potential allergens like nuts or gluten from conveying equipment and can be used with a variety of food types, such as nuts, grains, cereals, powdered soups, and frozen fruits and vegetables.
Although the CIP process is effective, streamlining its automation and simplifying the process for all of a facility’s tubular drag conveyors has been a priority for leading innovators in the industry.
“The standard system required port hookups to water lines and installing piping. The processor also had to make decisions such as which water temperatures to use, or whether to use a cleaning solvent—and the correct amount to add manually,” says John Adair, engineering and quality director for Cablevey Conveyors, an Iowa-based conveyor manufacturer that has designed, engineered, and serviced enclosed cable and disc tube conveyors for 50 years. Cablevey is in more than 65 countries.
To simplify the wet cleaning process, Adair and his engineering team at Cablevey have developed a small, mobile “smart cart” with integrated water line hookups that a single technician can easily take to any tubular drag conveyor in a facility. When the cart is in position and connected to water lines, the CIP process is automated and controlled by a programmable logic controller (PLC) that reduces the need for manual labor and negates the risk of improper cleaning.
“Once it is set up, all you do is press a button, and it will bring in the required amount of water at the correct temperature with the necessary amount of solvent for cleaning,” says Adair.
Cablevey’s smart cart stores and uses preprogrammed CIP recipes to flush various residual materials from tubular drag cable conveyors at the push of a button.
The smart cart is designed to store and use preprogrammed CIP recipes to flush various residual materials from the tubular drag cable conveyors in a facility before new production runs. The cleaning recipes enable even those with little training to use the cart. This is helpful in today’s tight labor market and allows the technician to move on to other tasks once the cleaning process begins.
The use of easily executable recipes ensures a superior, repeatable clean that essentially error-proofs the process. This is particularly important when a technician may be new or less familiar with the production equipment.
“[Depending on the product being conveyed], sometimes all you need is a wet rinse, or sometimes you need a specific cleaning solvent,” says Adair. “All that information is saved, so after the first cleaning, it can be automatically repeated. Just push a button to start [the appropriate recipe], whether you have one conveyor running multiple products, or dozens of conveyors running various products.”
To facilitate food safety compliance, the smart cart also documents all critical CIP information, such as water volume and temperature, chemicals used, and cleaning time by date in an easily retrievable data log.
Because decreasing production downtime between conveyor cleanings is a priority for food processors, Cablevey provides new capabilities with the cart that expedites the CIP process.
Currently, the CIP process floods the tubular conveyor system but isn’t designed to specifically clean the discs. “Operators would manually clean each disc and advance the system [disc by disc] when the discs had to be cleaned of particularly viscous substances,” says Adair.
Now, as an option on the cart, a disc washer can be integrated with the conveyor turnaround to spray a pressurized cleansing solution on the discs. This helps to remove stickier substances like chocolate that could remain after routine CIP cleaning.
“The disc washer sprays high-pressure water directly on the discs, so it acts like an automatic car wash. At the push of a button, the discs and cable are run through and spray cleaned, which reduces CIP time and eliminates the need to manually clean the discs,” says Adair.
To further reduce downtime, Cablevey also offers a new sanitary blower option.
“After the wet CIP process, a sanitary blower [attachment on the smart cart] can dry the discs and other parts of the system 75% faster than typical air drying,” says Adair. He points out that the faster the conveyor is cleaned and dried after a product change, the sooner it can be put back into service, which improves profitability.
According to Adair, Cablevey’s mobile smart cart is available for pre-order now, but will be officially unveiled at Pack Expo, a premier packaging and processing show held at the Las Vegas Convention Center, Sept. 11–13, 2023. The event features full-scale setups of machinery in action.
The company also plans to bring traveling demonstration smart carts to customers by September free of charge so they can try out the units. Food processors who like what they see may be able to purchase the demo unit used in their facility, with hands-on training immediately available.
While the food processing industry is aware that automated CIP can improve conveyor system production uptime, barriers to implementation have slowed adoption. Using a mobile smart cart with integrated water hookups will help processors to easily implement CIP in tubular drag conveyors throughout their facilities. This will expedite conveyor cleaning, production changeover, and sanitary compliance.
For more information, call (641) 673–8451. In the U.S., call toll-free (800) 247–3344, fax (641) 673–7419, email info@cablevey.com, or visit https://cablevey.com.
Cablevey’s smart cart is a fraction of the size of similar carts on the market, making it much more mobile.
Del Williams’s picture
Del Williams
Del Williams is a technical writer based in Torrance, California. He writes about business, technology, health, and educational issues, and has a master’s degree in English from California State University-Dominguez Hills.
