Featured Product
CMSC Features
Ryan E. Day
September Speaker Series in review
Ryan E. Day
Realigning a cornerstone of industry
David H. Parker
Practical implications for electronic distance measurement
Belinda Jones
Users of CMMs, industrial scanners, and portable metrology systems are urged to participate
Belinda Jones
Register for a day-long test-drive of 3DMU at no charge
More Features
CMSC News
New facility in Toronto area will showcase multiple Hexagon product lines
API division named ‘Top External Provider 2018’
Exact Metrology selected for project
Faster and more powerful than ever before
Accurate measurement out of the box
Engineering and design teachers will benefit from enhanced 3D scanning performance
Partnering with FARO Technologies
Structured-light 3D scanner for industrial design professionals
More News
XYLON
CMSC
YXLON Publishes New Computed Tomography (CT) Handbook
Published: Tuesday, August 8, 2017 - 10:29
(YXLON International: Hamburg, Germany) -- X-raying in 3D may seem straight out of a futuristic sci-fi movie, but with the recent advancements of Computed Tomography (CT) it is a reality, and a fast, easy, and affordable option. The newly published Computed Tomography (CT) for Industrial Applications Handbook makes it simple to understand what the process of CT scanning entails and how you can use it for your industrial applications. Busy engineers who are either experienced or novices at imaging will find simple methods and approaches for applying CT scanning technology to their industrial parts and subcomponents.
X-Rays in 3D: What is CT scanning?
CT starts by scanning an object and generating a series of 1D and 2D images at different angles. The separate images are assembled into one 3D representation of the scanned object using powerful imaging software. These images, called “tomograms,” are taken using X-ray scanning, usually through a full 360-degree rotation, and represent “slices” of the full 3D representation of the scanned object. The brighter the gray areas are in an image, the denser they are. Black is negative space. From these slices, the final 3D image is rendered, providing actual insight without destroying the item being imaged. Known as “volume rendering,” these pictures can have realistic shadows, opacity, camera angles, and more. Many times, even the 2D images are enough for engineers to get the information they need.
CT dates back to the early 1970s, with research by Godfrey Hounsfield and Allan Cormack, who eventually won the Nobel Prize in Physiology in 1979 for their work in using CT on the human brain. Its applications have since then extended beyond the human brain into various industrial and research applications.
Figures 1 and 2: Examples of 3D models CT can produce
Getting an inside perspective: What can be done with CT images?
As intriguing as the scanning process is, it is the applications of the images themselves that show the strength of this imaging technique.
An entire range of industries can benefit from CT scanning, including:
• Electronics
• Automotive
• Aerospace
• Foundry and casting
• Tire and wheel
• Welding
• Additive manufacturing
• Science and laboratory
CT scanning allows the inspection of raw materials, end products, and molds, along with other parts used in industry to ensure they meet quality and reliability standards without having to disassemble or destroy them. Engineers can get an inside look at construction techniques—for example, to see how well a weld has been applied between two pieces of metal, or to see if a critical jet-engine fan blade has any hairline cracks. It can show porosity levels in rubber, and examine new, lightweight parts for automobiles. Using CT scanning can help catch problems early before they turn into critical failures.
One of the most notable benefits CT provides is its ability to allow engineers to see densities. That means, for example, engineers can see inside injection-molded and 3D-printed plastic parts where voids and porosity are, as well as cracks, flaws, and other manufacturing defects using this nondestructive testing method.
Figure 3: Defects inside a part, classified by size
In metrology, CT can easily allow comparisons between surfaces. Two CT scans can be compared to each other, or they can be compared to CAD (computer aided design) drawings. The differences can be displayed by color for fast, easy identification.
Figure 4: Comparisons of surface scans
CT scans are also used in the analysis of concrete and structures. In these applications, the scans can help to show how fluid moves through core samples, to evaluate how concrete behaves before and after stress and fatigue tests, and to examine aggregate. CT scans can also allow inspection of lightweight materials used to reduce weight in automobiles, aircraft, spacecraft, and other vehicles.
Figure 5: A look inside a core sample
Beyond inspection and quality control, CT scanning can aid in reverse engineering. Engineers can get a literal inside look at a part without having to disassemble or destroy it. With CT scans, internal geometries and material densities are easily visible. The data gathered make it far simpler to understand how a particular part functions or if it meets necessary specifications. Computer software even exists for edge detection, if this is required.
Figure 6: Reverse engineering by measurements
Learn more
These are just some examples of what can be accomplished with CT scanning. For a full overview of applications, and to learn how CT can be of benefit to your single sample or production needs, download the YXLON CT handbook. It contains a wealth of information, including:
• Detailed descriptions of the CT scanning process
• In-depth examinations of applications
• Descriptions of the various components used in CT scanning
• Detailed looks at the beam and imaging technologies used
• Explanations of the software programs available
• Advice for designing employee training
• Notes on regulations to pay attention to
• Links to even further information
XYLON’s picture
XYLON
YXLON International designs and produces radioscopic and CT inspection systems for a broad variety of industrial applications and fields.
