Our children thank you.
Capture 3D
Published: Thursday, November 12, 2015 - 15:28 To reduce weight and fuel consumption, the aerospace industry increasingly relies on lightweight materials and new material combinations. That’s why the entire fuselage of the Airbus A350 XWB consists of carbon fiber composite (CFC) materials. In total, the long-haul aircraft reaches a CFC portion of 53 percent. In addition, Airbus uses materials such as titanium and new aluminum alloys. As a result, the A350 consumes about one-quarter less fuel than conventionally constructed aircraft, and environmentally harmful CO2 emissions are reduced correspondingly. However, these lightweight materials and new material combinations must meet the same high standards of performance, safety, and durability as traditional materials. Accordingly, the materials and the components manufactured from them are tested intensively. To this end, the aerospace industry increasingly relies on optical metrology. The noncontact systems provide data for part geometries as well as for 3D displacements and deformations. Static and dynamic deformations are determined based on individual points or full-field measurements. The measurement data optimize simulation and design processes and thus increase aircraft safety. Before certification, the A350 had to pass intensive tests. Airbus supplier FACC examined fiber composite materials and components of the A350 at the Composites Lab and Test Center (CoLT), a subsidiary on the company’s premises in St. Martin, Austria. Tests for the certification of the winglets and wingtips were especially extensive. The entire element, with a length of more than 6 m, was analyzed statically and dynamically in a special testing facility for long-term and peak loading. The tests also included damage tolerance testing. These analyses were necessary because the component mainly consists of fiber composite materials with metal connections. The load, fatigue, and damage tolerance tests provided information about the structural behavior of the component. Along with standard measurement techniques, for the first time, the FACC subsidiary fully integrated PONTOS noncontact sensors from GOM in the test setup. Unlike conventional methods such as strain gauges, the two PONTOS systems recorded 3D displacements and deformations of the winglet. In total, as seen in figure 1, the test object was 8 m long, 2 m high, and 3 m wide; about 110 tons of steel were used on the test stand (14 m long, 8 m high, and 10 m wide). Loads were achieved with 15 servo hydraulic push-and-pull cylinders, with the force transmitted by five yokes. The two PONTOS noncontact sensors measured dynamic deformations at around 220 points, with each point being analyzed three-dimensionally in the x, y, and z directions. In addition, more than 2,000 synchronized channels measured static strain, deformation, force, pressure, and temperature, as see in figure 2. On the actual A350, the winglet and wingtip—the inside elements of the assembly—are fixed on the main wing box. To realistically reflect these connection points and the behavior of the main wing box during the test, a dummy wing box was used. It was specifically designed for the test and is identical to a real wing box in terms of material properties and connection of the winglet. During structure testing, the component was loaded statically across several stages to simulate the loads occurring during flight. In this way, the test engineers examined three scenarios: maximum torsion, and maximum load upward and downward. During fatigue testing, the engineers ran through real flight profiles to analyze the behavior of the component within one life cycle. During static and fatigue testing, load factors were applied to account for variations in the material properties and possible weight increases in the component. For the damage tolerance tests, the winglet was damaged in advance at certain points. This way, the test engineers simulated manufacturing errors, as well as damage caused by hail impact and bird strikes to precisely analyze the effects on material and component behavior under load. Unlike conventional measurement devices such as strain gauges and transducers, optical systems such as PONTOS can determine 3D displacements and deformations while additionally measuring real speed and acceleration. The evaluation of the point-based data enabled full 6DoF analyses. This way, test engineers could see exactly how the winglet moves in space and at which points it is particularly deformed, as seen in figure 3. The PONTOS system can be easily integrated into the test setup, with inspection points identified by measurement markers. Using an optically tracked touch probe, nominal positions can be determined and adapters can be measured. With the new PONTOS Live software module, the test run could also be measured online, enabling users to see directly in the software what happens during testing. Additionally, the measuring data could be communicated to other programs via a digital interface and could be processed directly by them. It was also possible to record and process analog signals from external measuring devices. Optical measuring systems also accelerated test setup. For instance, 200 strain gauge positions, which were defined in advance by Airbus and CoLT test engineers, were marked and applied to the component within one working day. To do so, the company Westcam, GOM’s distributor and service provider in Austria, first measured the winglet and its components with the portable photogrammetry system TRITOP, which captures 3D coordinates of objects. After the measuring data were aligned to CAD, the 3D scanner ATOS performed a back projection of the strain gauge positions, as see in figure 4. During this process, the sensor projected the positions directly on the winglet, based on the measurements. The positions are visualized as 3D elements in the CAD software. Staff from CoLT simply marked the correct points, which led to considerable time savings. Up until that point, it was very labor intensive to determine the positions with measuring tapes, starting from the edges or bore holes. For demanding geometries, such as at the inner side of a leading edge, positioning using conventional methods was very complicated, due to the strong bending. Using GOM systems it was possible to accomplish these tasks in a fraction of the time. Optical metrology also allowed the positions of the applied strain gauges to be checked. They could be measured again with TRITOP photogrammetry or the handheld GOM Touch Probe and compared with the CAD data. Lightweight materials are an essential part of the aerospace industry. Correspondingly, OEMs and suppliers test the new materials intensively to guarantee their performance, safety, and durability. Optical measuring systems can be easily integrated in different test stands; at the same time, they determine static and dynamic deformations via point-based and full-field inspections. The results are available immediately after the measurement and can be displayed in easy-to-understand charts, videos, and images. One important area in which 3D measurement data are used is simulation verification. Modern flight vehicles are extremely complex, so everything is simulated during the development process. To compare the simulations with reality, comprehensive 3D measurement data are necessary instead of just a few individual signals. The results enable users to review and improve simulation parameters, as well as to optimize current and future design processes. Therefore, they can reduce the number of costly test runs and consequently speed up product development. At the same time, the 3D measurement results allow conclusions to be drawn on safety risks, part durability, and creep and aging processes. This increases not only the safety but also the lifetime of products. FACC Operations is one of the world’s leading companies in the design, development, and production of fiber-reinforced composite components and systems for the aviation industry. Its range of products reaches from structural components for the fuselage and wings, to engine components, and complete passenger cabins for commercial aircraft, business jets, and helicopters. FACC is a supplier to all large aircraft manufacturers, including Airbus, Boeing, Bombardier, Embraer, Sukhoi, and COMAC, as well as to engine manufacturers and their suppliers. The Composites Lab and Test Center on FACC’s premises in St. Martin, Austria, started operation in 2013. It gives FACC one of the most modern facilities for analyzing, testing, and certifying fiber composite materials and components. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Capture 3D provides 3-D digitizer, surfacing, laser scanning, and dimensional inspection services. It also designs, manufactures, and supports 3-D scanners, and automated robotic and motion control systems. Capture 3D’s high-resolution, optical scanner, ATOS, delivers 3-D measurement data for industrial components. Instead of measuring single points, full part geometry is captured in a dense point cloud or polygon mesh describing the object’s surface and primitives precisely. Capture 3D is headquarted in Costa Mesa, California.Optical 3D Metrology Supports Certification of Airbus A350
Optical metrology replaces conventional methods
Noncontact measurement of 3D displacements and deformations
Figure 1: The winglet is 8 m long, 2 m high, and 3 m wide. About 110 tons of steel were used on the test stand. For the first time, FACC fully integrated noncontact sensors from GOM in the test setup.
Figure 2: The PONTOS sensors measure the dynamic deformations at around 220 points, each of which can be analyzed in three dimensions.Complete 6DoF analyses
Figure 3: The evaluation of the point-based data enabled full 6DoF analyses. This way, test engineers could see exactly how the winglet moves in space and at which points it is particularly deformed.
Figure 4: For an accelerated test setup, the ATOS 3D scanner performed a back projection of the strain gauge positions.Back projection of strain gauge positions with ATOS
Simulation verification based on 3D measurement data
CoLT Composites lab and test center
Quality Digest Discuss
Capture 3D
