InnovMetric Software
Published: Thursday, May 21, 2015 - 15:52 E xtreme Fab Inc. is a structural metal fabrication company that has the tools and skills to build the massive machinery that the oil and gas, power, energy, and trucking industries require. One of their key customers is GE Aero Energy, a company that gives businesses and communities around the world the ability to generate reliable and efficient power at or near the point of use, at any time—on or off the grid.
Using a wide variety of fuels, GE Aero Energy's FlexAero LMS100 aero-derivative gas turbine generates up to 100 megawatts of electricity at a conversion efficiency of 44 percent. Made for rapid deployment and installation in isolated locations, such as remote villages, drilling sites, or disaster areas, this exceptional turbine is a power plant in a box. The LMS100 package includes the turbo, gas turbine, and compressor, all mounted and pre-assembled. To make this sophisticated piece of engineering work requires the use of a large, high-precision skid. When it comes to machining skids for GE Aero Energy, Extreme Fab partners with Dimensional Engineering, which provides 3D digital data capture, engineering, and analysis services to address design and production engineering challenges across a broad range of industries and applications. Measuring 60 ft by 25 ft, the LMS100 skid has precisely machined bearing surfaces and mounting holes. The slightest machining deviation can decrease the power plant's operational efficiency, energy output, and service life. According to William Bonner, managing director of Dimensional Engineering, "Mounting pads require a flatness of ± 0.002 in. and elevations held to ± 0.005 in., relative to all locations across the skid's 60-ft length." Machining a large object to that precision is no easy feat, but the skid is even more challenging. "This thing moves; it's never static," says Bonner. One-ton field machining systems sit on the skid while making the precise cuts. "Every time you place the mill on the skid, it flexes because the mill's weight is not distributed equally." Throughout the 10-day, 12-hour-a-day project, machinists relocate the equipment, causing the mounting pads to rise, fall, twist, and turn. Thermal expansion is also a factor that further complicates matters. With considerable temperature variations of up to 50° F (10° C) over a 24-hour period, the skid expands and contracts throughout the day. "Dimensional Engineering's role is to control the setup and dictate cutter angles and depths so that Extreme Fab can deliver the precision that GE demands," says Bonner. If the skid arrives at GE and it doesn't meet the required specifications, there are often dire consequences. "It costs thousands of dollars just to ship the skid one way, so if it has to come back to Extreme Fab for reworking, there can be tens of thousands of dollars in additional transportation costs alone," Bonner explains. If reworking affects production schedules, nonconformance can also mean significant financial penalties. With every machine move, before each cut and after each operation, Dimensional Engineering provides Extreme Fab precise measurements for mill placement, cutter position, and the position of the workpiece relative to the skid's static, relaxed state. Without this measurement control, GE's specifications would be tough, if not impossible, to meet. Bonner said that his tools of choice are FARO laser trackers and InnovMetric's PolyWorks|Inspector software solution. "We use the laser trackers to capture precise measurements and PolyWorks to study and manage the data collected to direct the ever-changing project." Bonner's two-man team starts with a basic alignment of the skid in its relaxed state. Using 50 reference targets welded to the workpiece, the laser tracker measures the datum features of the skid, and PolyWorks is used to create a world coordinate system. PolyWorks is then employed to establish multiple local coordinate systems that allow the team to isolate movement on an individual mounting pad while maintaining the relationship to the entire skid. After positioning and levelling the mill, Bonner's team measures the skid and the position of the cutter to provide exact locations that machinists use to program the cut depth and angle. When the operation is complete, measurements are taken once again to verify the cut prior to making another pass. Because the skid changes with temperature, the Dimensional Engineering team processes all measurement data using the dynamic temperature compensation functionalities that PolyWorks offers. This adjustment, combined with the exact location of the machined feature, allows the machinists to program cutter paths relative to the skid in a stable temperature condition rather than its current, dynamically changing position. Due to the skid's size and line-of-sight considerations, the FARO laser trackers are repositioned dozens of times over the 10-day project. This introduces yet another variable to the precise machining operation. To make sure that all measurements are precise relative to all tracker positions, Bonner's team uses PolyWorks' move device and real-time bundling. As Bonner states, "If we couldn't control the measurements considering the tracker repositioning, there would be big problems." To finish the project, a final inspection is conducted to confirm that the skid meets GE's specifications. "We validate and certify every measurement, both during the project and before the shipment," concludes Bonner. "Without the use of the laser tracker and the PolyWorks|Inspector solution, there would be no way to achieve this level of accuracy and precision, at least not in a quantifiable way," says Bonner, "We have been doing this work for six years and have worked on more than 50 skids. None of them have had to make that expensive round trip for rework." In those six years, Dimensional Engineering has had only two nonconformance reports (NCRs): One was for a single out-of-spec hole, and the other was because of conflicting specifications in the skid's drawings. Dimensional Engineering applies the same process and tools to other large-scale projects, including auxiliary components for the LMS100 package, such as the intercooler. "The skid techniques are used to position two 50-ft radiator mounting rails while they are being welded, 120 holes on the radiator mounting flange, and parallelism on intake and output flanges," explains Bonner. "Without precision measurements that we obtain from the FARO laser tracker and PolyWorks, the radiator would not fit in the intercooler, and the intercooler would not seat properly with the LMS100 turbine." With PolyWorks, Dimensional Engineering makes moving targets manageable and large-scale machining predictable. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Founded in 1994 and headquartered in Quebec, QC, Canada, with subsidiaries worldwide, InnovMetric Software Inc. is the leading provider of universal 3D metrology software solutions. The world’s largest industrial manufacturing organizations (Toyota, General Motors, Volkswagen, Honda, BWM, Daimler, Ford, Rolls-Royce, Pratt & Whitney, Boeing, Embraer, Bombardier, Apple, and many more) trust InnovMetric’s PolyWorks software and associated technical services to maximize the benefits of 3D measurement technologies for their engineering and manufacturing applications. Including its subsidiaries and joint ventures, InnovMetric Software has more than 250 employees across 10 countries: Canada, United States, Mexico, Brazil, France, Benelux, India, Thailand, China, and Japan.Moving Targets: PolyWorks Helps Preserve GE’s Power Plant Output
Figure 1: The LMS100 aeroderivative gas turbine.
Figure 2: The pre-assembled LMS100 package (center) is the heart of a power generation facility for isolated locations.The challenge
Figure 3: Rendering of the 60 ft x 25 ft, precision machined skid. Bearing surfaces (green) are machined to ± 0.002 in. flatness.
Figure 4: Machinists make adjustments to the one-ton field machining system.
Figure 5: Milling occurs only after precise measurements that are adjusted to compensate for skid movement.The solution
Figure 6: Final inspection results confirm flatness on a mounting surface.
Figure 7: The finished skid being prepared for transport to GE.The benefits
Quality Digest Discuss
