Our children thank you.
InnovMetric Software
Published: Wednesday, November 10, 2010 - 13:59
The design, developed by Aerodynamic Trailer Systems, is an inflatable boattail constructed from a heavy-duty flexible polymer material that automatically inflates and deflates by means of a blower and valving system at pre-set highway speeds. The deflated position overcomes a design challenge by allowing the rear doors to be fully opened for loading freight.
“The inflated boattail is a uniquely curved shape that is very difficult to pre-determine on engineering drawings or measure, which makes it difficult to model,” says Jim Domo, CEO of Aerodynamic Trailer Systems. “We wanted to measure the aerodynamic profile of the device. Since a truck trailer is too big to fit in a wind tunnel facility, we needed to create a scaled model that would describe the exact physical shape. In parallel, we needed a digital version of the boattail, in order to perform a software-based CFD analysis.”
Scanning the boattail
Point cloud of the digitized boattail
Aerodynamic Trailer Systems contacted 3D Scan IT Inc. to discuss alternatives to traditional data-gathering techniques. 3D Scan IT is a metrology company, and the North American integrator of PolyWorks point cloud processing software. They’re headquartered in Royal Oak, Michigan. 3D Scan IT technicians recommended a noncontact high-density scanner as a data-gathering approach, and brought a Imetric-IScan white light scanner to the company’s facility.
“We first used photogrammetry to set up navigation points on the surface of the boattail, and then we performed a complete scan using the Imetric white light scanning system,” says Bob Squier, president of 3D Scan IT Inc. Setup and photogrammetry took about two hours including calibration of the scanner, targeting the part, and performing the photogrammetry. The scanning process took about three hours.”
The data was acquired using the PolyWorks software suite from InnovMetric Software Inc. of Quebec City, Canada. A total of 62 scans were taken and registered to the photogrammetry coordinate system. A tolerance-controlled best-fit alignment of the scans was performed in the PolyWorks IMAlign module. The aligned scans were then processed using the PolyWorks IMMerge module to create a polygonal mesh that removed all the overlapping scan data while removing the fabric texture and reducing the file size.
The polygonal model was then brought into the PolyWorks IMEdit module to remove photogrammetry targets. A watertight polygonal model was created using in the IMEdit functionality of curvature-based hole-filling procedures.
Polygonal model ready for rapid prototyping
Prototype model created from
ATS also wanted to test the boattail performance in a wind tunnel. “The goal was to create a file that we could use in a rapid prototyping process to quickly create a 1/8 scale model of the boattail device that would be used for performance testing in a wind tunnel,” says Patrick Ryan, president of ATS.
To perform the simulation, the polygonal model was sent to Auto Research Center in Indianapolis, Indiana. This wind tunnel testing facility, designed primarily for testing race cars, is an open jet, rolling road design that accurately replicates highway conditions.
To create a scaled model of the boattail, the specialist at Auto Research Center used a Stratasys FDM 8000 rapid prototyping machine, and the watertight polygonal model created by 3D Scan IT Inc. to build the part in ultra-thin layers from strong ABS plastic.
“We planned to use that wind tunnel test data to make any last-minute design changes to the device before we went into production, so it was critical to our program that the model be as accurate as possible,” Ryan says.
In addition to the wind tunnel testing, ATS wanted to perform a computerized fluid dynamic analysis. In order to perform this CFD analysis, 3D Scan IT prepared a surfaced model (NURBS model) using the PolyWorks IMEdit module.
First, a curve network was created by using the curve extraction and editing functionalities of IMEdit. Automatic NURBS surface fitting procedures create the surfaces as the curves are completed. The PolyWorks IMInspect module was used to align the model to the global coordinate system of the trailer doors since the boattail had to exactly fit the door area without obstructing the hinges.
The optimized NURBS model was sent to specialists from NASA to perform CFD analysis. This software provided a quick overview of the aerodynamic performance of the inflatable boattail under various conditions.
NURBS creation process
NURBS model ready to be exported to CFD software
The NURBS model was also exported to ATS’s SolidWorks software suite, who will be able to use it for future modifications and production purposes.
According to Domo and Ryan, the 1/8 scale model of the boattail created by the laser scanning and point cloud data management process was a dimensionally precise model of the full-size device, virtually an exact replica.
“We were confident that when we conducted wind tunnel testing we would get meaningful results that would apply directly to the full-size device,” Ryan says.
Test results indicated that the boattail could reduce fuel consumption by up to 5 percent.
“That translates into fewer emissions and reduced fuel costs through the improvements in aerodynamic drag on the trailer, which decreases the effective load that the tractor must pull, thus improving efficiency,” says Domo. “Plus, we believe that with some minor shape modifications to the device, we can improve our profile even more.”
He added that the use of scanning technology and point cloud data management reduced the time to create the model “by orders of magnitude. We were able to get to a precise model in just days,” he says.
Bob Squier of 3D Scan IT Inc., says that this application was unique in that the entire design and manufacturing process relied on scanning and the refinement of point cloud data, plus rapid prototyping. “A traditional approach to product design and development would simply not have achieved the results the company was looking for.”
All images courtesy of InnovMetric Software Inc.
Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Founded in 1994 and headquartered in Quebec, QC, Canada, with subsidiaries worldwide, InnovMetric Software Inc. is the leading provider of universal 3D metrology software solutions. The world’s largest industrial manufacturing organizations (Toyota, General Motors, Volkswagen, Honda, BWM, Daimler, Ford, Rolls-Royce, Pratt & Whitney, Boeing, Embraer, Bombardier, Apple, and many more) trust InnovMetric’s PolyWorks software and associated technical services to maximize the benefits of 3D measurement technologies for their engineering and manufacturing applications. Including its subsidiaries and joint ventures, InnovMetric Software has more than 250 employees across 10 countries: Canada, United States, Mexico, Brazil, France, Benelux, India, Thailand, China, and Japan.Improving Fuel Efficiency With Point-Cloud Engineering
Digitizing a challenging shape
Aerodynamic Trailer Systems Ltd. (ATS) of Auburn, Ohio, has developed a new product that fits on commercial trailer doors to provide a more aerodynamic shape to the rear of the trailer. The object is a “Green Technology” to reduce emissions by improving fuel efficiency of over-the-road trucks. The product, a boattail, is an aerodynamic device that reduces drag caused by air flowing in a random, turbulent manner around the rear of a commercial trailer. It effectively changes the flat surface of the rear doors to a curvilinear shape.
Solution—Point-cloud data management delivers quick results
PolyWorks STL model
Wind tunnel testing
CFD analysis
Benefits—Reducing fuel consumption by up to 5 percent
Quality Digest Discuss
