Our children thank you.
Nikon Metrology Inc.
Published: Thursday, February 12, 2015 - 15:50 Kiekert AG, the global leader for automobile door lock systems, now uses digital cross scanners by Nikon Metrology to test the positions and dimensions of sealing lips on door and rear compartment locks. Tactile inspection methods are unable to correctly measure these touch-sensitive and complex free-form components. It’s about 30 centimeters long, eight millimeters thick, smooth, soft, with a curly form. It’s completely insensitive to cold, heat, damp, dust, or dryness. It can live for several decades—despite the fact that it spends its entire life in the dark. It’s a very special species, unknown even to biologists. It’s a foam gasket seal. Unnoticed by the human eye, it curls itself up just 10 centimeters from the left or right upper arm of virtually every driver or passenger in the door lock of all vehicles bearing the blue-and-white BMW emblem. Here, between the interior and exterior door panels, is the habitat of the foam gasket seal, and here it fulfills its one and only purpose in life: to seal the vehicle latch-closing system hermetically against moisture and dirt from outside, which ensures that the lock will work anywhere in the world, even in the harshest of conditions. Like more than 50 other automotive manufacturers, BMW favors Kiekert AG’s technology for high-quality locking systems. Based in Heiligenhaus, Germany, near Dusseldorf, the global leader for the supply of automotive door lock systems operates in nine countries around the world, with a total of around 5,000 employees. Six of these locations are production centers, five are involved in R&D, with three sales and distribution centers. Holding more than 1,200 patents, Kiekert AG, where central locking and electromotive power servo locking were invented, is the uncontested leader of innovation in this challenging field of technology. This is also where engineers are hard at work developing various solutions to make driving even safer and more comfortable in the future. It’s also a place where the quality assurance processes offer very special guarantees. With foam gasket seals, only completely healthy specimens are released, up to 20,000 a day in the plant in Heiligenhaus alone. The body of the caterpillar-like bead is made of a special, malleable dual-component foam which is applied to the shell of the lock by a robotic spray system, in a serpentine shape about as thick as a pencil. As a compressed sealing lip between the lock and the door panel, the foam gasket seal prevents any moisture from entering the lock system. Because door locks and rear compartment locks are not generally replaced or serviced during the life cycle of the average car, the foam gasket seal has to function reliably for several decades. To do so, it has to be shaped with utmost precision because even the smallest deviation in the profile, surface outline, or position could cause acute long-term damage to the locking mechanism. It’s hardly surprising, therefore, that Kiekert has singled out the foam gasket seal as a part which most definitely has to pass a quality assurance inspection independently of the verification Kiekert demands for the quality of the part. When production of the foam gasket seal began, Kiekert initially approached the issue, in agreement with the customer, via touch-trigger probing on coordinate measuring machines (CMMs). This solution was completely viable, and customers were certainly satisfied. But Kiekert’s highly critical quality assurance team was sure there was room for improvement. Even using the lowest force of 0.2 Newtons, the contact probe’s tip made a slight indentation in the soft foam material. This deformation righted itself again naturally, but it caused a small amount of inaccuracy. The optimum probing angle with early triggering was ascertained following a long series of tests. This minimized the effect, but there were other aspects of contact (tactile) measurement which proved to be less than ideal. The most disadvantageous: the foam gasket seal is a complex 3D surface profile, so measuring only one dimension is not sufficient. Information is required regarding its height, cross-section, profile geometry, and position. Ultimately, tactile measurements cannot portray all this, due to the limited points measured on a bead. The process would be extremely time-consuming for a complete overview using tactile measurement, not to mention the laborious evaluation of so many tactile inspection points. It would be difficult if not impossible, however, to maintain the desired overview by cutting down the number of inspection points. Time was a rare commodity in the Kiekert quality assurance department for BMW door locks with attached foam gasket seals. More and more components were arriving in the central measurement room for sampling inspection, and the limit had almost been reached. Fortunately there was also an exciting solution at hand, though it involved a complete paradigm shift, from contact to noncontact measurement. Goodbye probes, welcome scanners. Kiekert had already gained intensive experience with single-line scanners, particularly in the component qualification of so-called “prototype parts.” As soon as laser scanner technology came on to the market at the beginning of the millennium, the potential of this measuring technology was recognized in Heiligenhaus, and it was implemented step-by-step in the quality assurance process. Hence, for some time, 3D laser scanners made by the measuring equipment manufacturer Nikon Metrology have been used not only in the German production site in Heiligenhaus, but also in Kiekert’s largest plant in the Czech Republic and at the site in Mexico. At all these locations, the enormous advantages offered by noncontact laser scanners are impressive: With the introduction of the newest evolutionary phase in Nikon technology, the XC65Dx digital Cross Scanner, Kiekert has now drawn foam gasket seals into the crosshair of the laser. The crosshair comparison hits the mark. With its three lasers positioned crosswise to each other, Nikon Metrology’s XC65Dx digital Cross Scanner is able to digitize not only surfaces, but also features like pockets, holes, slots etc. This can also be applied to the complete, complex profile of the touch-sensitive foam gasket seal in Kiekert’s latch-closing systems. Notably, this is all done in a single scan, with the foam sealant passing through just once. Thanks to the fact that the laser lines come from three different angles, the repositioning of the scanner during the scan is reduced. The field of vision covered by the three laser lines is 65 × 65 mm, and the precision level of the sensor is 12 μm. Three scans in one pass equates to a huge saving in time. The XC65Dx Cross Scanner, which operates on a Nikon bridge coordinate measuring machine, takes under four minutes to measure the entire foam gasket seal. During this time, the high-performance data processing generates a high-density 3D point cloud from a scanning speed of up to 75,000 laser points per second. Thanks to the comparison color reports of the Nikon measurement software, the operator receives an evaluation of the test and deviation results, which is meaningful even at first glance. Even those who have not received explicit metrological training only need to look at the colors to interpret the deviations. This is certainly an important aspect when measurements are not only taken in the measurement room (as with Kiekert) but also close to production or alongside production. Additionally, specific characteristics from the 3D point cloud are extracted and statistically monitored to regulate the foaming process. This way process trends are corrected before the agreed tolerances are exceeded. Shorter measuring times, high-precision, complete 3D view, simple to operate, fast analysis of results... these advantages alone are convincing arguments in favor of Nikon Metrology’s Cross Scanner technology for inspecting foam gasket seals. And the advantages don’t end there—parts don’t have to be sprayed with matte spray in a time-consuming process to rule out unwanted reflectivity. The basis for this is the permanent, automatic point-to-point adjustment of laser source intensity of Nikon Metrology’s XC65Dx. It individually configures up to 75,000 points per second, thus guaranteeing a homogenous, complete point-cloud picture without flare. Changes in the testing process, i.e., for different lock types, are not a problem either because the necessary scanner movements can be generated automatically offline, based on CAD data. Using Nikon Metrology’s Focus Scan software, inspection programs can be run directly as required, even by operators without advanced metrology programming skills. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Nikon Metrology Inc. offers the most complete and innovative metrology product portfolio, including state-of-the-art vision measuring instruments complemented with optical and mechanical 3-D metrology solutions. These reliable and innovative metrology solutions respond to the advanced inspection requirements of manufacturers active in aerospace, electronics, automotive, medical, consumer, and other industries. Systems are available in both fixed and portable configurations, equipped with single or multiple sensors. Foam Gaskets Seal In the Line of Fire
Laser scanner advances 3D inspection at automotive supplier Kiekert AG
The Cross Scanner digitizes complex multi-material assemblies in an easy and fast inspection processThe challenge: quality to last for decades
The limits of tactile measurement
Inspecting the foam gasket seals using tactile inspection is inaccurate as even the slightest force of the contact probe’s tip makes an indentation in the soft foam materialDecisive laser advantages
• Creation of high-density point clouds for quickly identifying form and features
• Initial and detailed analysis of surfaces and sections considerably simplified due to color charts
• Fast measurements of free-form surfaces possible
• CAD characteristics tests
• A complete digital copy of parts acquired in just a couple of minutes
• Reduced measuring times, hence increased throughput
• Simplified processing of measuring data to be passed on to existing processing and evaluation software
• Reverse engineeringCross-scanning with three laser lines
Pinpointed precision for laser intensity
Quality Digest Discuss
