Our children thank you.
Ray Ryan
Published: Monday, August 22, 2011 - 09:47 The National Institute of Standards and Technology's (NIST) Center for Neutron Research is expanding the number of beamlines for research purposes from seven to 11 beams. The metrology tasks required to perform the installation of the new beamlines include the design and installation of a high-accuracy control network throughout the area affected by the new beamlines, the measurement and fiducialization of 145 new glass guide segments, the alignment of each glass guide segment in its vacuum vessel, and the positioning of the all the vacuum vessels within three distinct areas of the facility. For the NIST engineers, the project's challenges included a restrictive schedule and severe visibility restrictions within the building. This required careful planning to achieve the required accuracy. This article describes the challenges as well as the methods used by the metrology team to overcome them. The team's efforts provided a highly efficient method of performing the alignment and allowed nonmetrologists to perform the measurement and alignment tasks with minimal assistance. • NIST—National Institute of Standards and Technology
The NCNR is expanding its facility to accommodate greater demand for research time using the center's cold-source neutron beams. ECM Global Measurement Solutions (ECM), under contract with the NCNR, is assisting the NCNR alignment team with designing, installing, and aligning four new beam lines to the facility. The new beam lines required NCNR to construct an additional beam hall adjacent to the existing beam hall and to create penetrations through a 5 foot-thick concrete containment wall surrounding the neutron reactor. The image in figure 1 provides a general overview of the facility, including the reactor in C Hall, and the beam lines passing from C Hall into the new guide hall (G Hall).
The NCNR alignment team was faced with several daunting challenges in planning and executing the expansion of the beam lines. There was limited access to containment areas, pressing schedule constraints, the highest order of accuracy requirements, and restricted visibility along the course of the beam line. To address these challenges, the following methods were employed: • Establishing a facilitywide control network
To accurately align four beam lines spanning hundreds of feet to an accuracy of 0.002 in. requires a highly accurate control network of points valued in the project coordinate system. No measurement instrument exists that can value these points to the level of accuracy required, so a combination of instruments was used and overlapping measurements were taken from multiple locations to achieve the necessary accuracy. The measurements are "bundled" together in a highly sophisticated software package to generate statistically valid measurements with computed measurement uncertainties for each point in the control network, based on the number and location of instruments used to measure each point. The software used for this effort is New River Kinematics (NRK) Spatial Analyzer (SA) software. NRK's Unified Spatial Metrology Network (USMN) routine within SA allows measurements from several different instruments taken from multiple locations to be combined into a singular network with accompanying accuracy statistics on how well each point is spatially defined in the network. The software serves two distinct purposes in the valuing of the control network: to compute the x, y, z values and the uncertainties associated with these values; and as a design tool. SA has a simulation function that allows planners to determine, before going into the field, the number and location of measurement devices that will be required to achieve the level of network accuracy desired. For the NCNR project, the control network starts in the reactor room (C Hall), transits through a utility room (D Hall) and enters the new guide hall (G Hall). A screen shot of the network during the design phase in SA is shown in figure 2. The CAD representation shows control point locations, measurement instrument positions, lines of sight between the points and instruments, and various features within the rooms for general orientation. The overall size of the three halls is approximately 200 ft by 600 ft and requires passing the control network through a small opening in the wall common to the C–D halls. From an accuracy standpoint, this area is the weakest point because the entire network "hinges" about this narrow aperture. For the control network measurements, three types of measurement devices were necessary to achieve the project accuracy requirements: a laser tracker, a total station, and a digital level. Figure 3 provides images of the three instruments. The laser tracker does most of the measurements but lacks the range to correlate points that are further than 100 ft from the instrument. This is where the total station provides the capacity to measure distances up to the entire length of the project from one instrument position. The remaining instrument, the digital level, helps enforce a level plane between points across the entire project. This is not always possible due to limited visibility between the three halls and cannot be guaranteed by the use of only the laser tracker or a total station. To accomplish the accuracy required for positioning the beam line components throughout the facility required the use of 88 laser tracker positions, 12 total station positions, and four level loops. The specific position and orientation of the instrument positions was determined using the simulation mode in the SA software. Figure 4 depicts the instrument positions; the lines represent the individual lines of sight between each instrument and the points measured. It becomes clear that the number of observations throughout the facility is considerable to achieve the desired accuracy. The resulting accuracy calculations provide a 2 sigma (95% confidence interval) statistical indication of the point uncertainties using the proposed network of instruments and point locations. Table 1 represents a sample output of the simulation results. Once the actual measurements are collected, the real observation data can be run through the same software program and the resulting point uncertainties calculated. With the network of instrument positions and points designed, the most challenging aspect of the control network is the measurement process. Data must be collected with as much care and exactness as possible. The stability of the instruments on their stands must be checked, and temperature of the environment must remain stable and monitored throughout each measurement session. Instrument compensation parameters must be checked to validate that the equipment is operating at its peak performance. For the NCNR facility, the visibility within the reactor hall (C Hall) as well as the limited visibility between the utility room (D Hall) and the adjacent reactor and guide halls presented a significant challenge in both establishing the control network and planning and executing the installation of the beam line. From the images in figures five and six, it is clear that visibility is severely restricted. Figure 5 shows the reactor within the C Hall extending from the floor up to the ceiling, blocking sight lines to points across the hall. Figure 6 depicts the limited lines of sight between the C Hall and the D-Hall. This narrow opening not only limits visibility but also presents a geometric weak point of the control network measurements for the project. Note that a second opening is in the process of being cut through the 5 ft concrete wall. The difficulty of the task was magnified by the need to cut the penetration at an angle to the wall. The alignment team was able to complete the necessary data collection and the resulting network accuracy met the project requirements. This validates the use of the SA simulation software as a good planning tool for complicated networks. Additionally, this network will need to be checked as the loading of the floors with glass beam segments, vacuum vessels and heavy steel shielding is added to each area. Typically, the control network will show movement greater than the accuracy requirements and will need to be measured at least a second time to quantify the settling and movement. This has not yet been performed on the NCNR beam expansion project, but is in the project schedule.
For the new beam lines, 145 new glass beam line segments were acquired from a supplier in Switzerland. These glass "boxes" are highly accurate, highly polished, nickel-coated components that direct the neutron particles from the reactor along the beam line to the experiments in the guide halls. Figure 7A shows four of the glass segments with measurement pucks epoxied to the sides and a protective cover on the ends to keep out dust and prevent damage. Figure 7B provides a unique glimpse at the interior of the glass beam guides prior to joining. The pucks are used as auxiliary points to locate the glass segments once they are placed in their vacuum vessels. These points also are known by a more technical term, fiducials. The fiducials have values relative to the geometric center of the glass beam line segments. Once the beam segments are placed in their vacuum vessels, the fiducials are all that are visible, and the centers are covered by adjoining beam segments. To value the fiducials, each beam segment is measured using a portable coordinate measuring machine (CMM) arm at the four corners of each end, and then the centerline is calculated. The fiducials are then measured and given values relative to the position of the beam segment centerline. The end planes are also measured to give the fiducials values along the beam line relative to the starting point of the beam line. Complicating the location even more is that each beam line is actually not a true line but a very large radius curve. The radii vary by beam line but are as large as 20,000 in. (2,500 ft), and the beam segments must be placed tangent to the curved beam path as they are aligned along the nominally designed path. Figure 8 depicts a beam segment being measured using the portable CMM arm. This process is repeated for all 145 beam segments, and the values of the fiducials allow the placement of the beam segment in its proper location along the beam line. The key challenge in measuring the beam segments and valuing the fiducials was placing the fiducials where they would be most visible once they were installed in the vacuum vessel, and ensuring the fiducials were valued based on where the glass segment was to be installed along each of the four new beam lines. Figure 9 provides a graphical representation of several beam segments in a vacuum vessel. The vessel "windows" had to be designed during the early stages of the project to coincide with the location of the fiducials so they would be visible during alignment. The alignment team worked closely with project engineers to ensure that the windows and fiducials were properly located to maximize visibility from proposed instrument locations. In the figure 10, an actual picture of a vacuum vessel provides confirmation of the coordination of the fiducial placement and the windows installed in the vacuum vessel.
Due to schedule constraints limiting the access to the reactor and utility halls during the beam line expansion construction phase, the beam segments had to be installed in the vacuum vessels in temporary locations and then moved to their final positions after the building modifications were completed. The allowed other construction tasks to be conducted while alignment proceeded. Only when construction was completed, including the machining of the new concrete wall penetrations, could the vacuum vessels be relocated to their final locations in the reactor hall and utility room. The assumption here was that time spent performing the final alignment would be significantly less than the time required if the alignment were to begin from scratch. This was validated as the project proceeded. The major risk was that when the vessel was moved into its final location, the glass beam segments might move. Luckily for the project, this did not happen. The Reactor Hall components were temporarily assembled in the adjacent High Bay Hall. Figure 11 shows the assembled vacuum vessels for four distinct beam lines. By assembling the vacuum vessels and installing the beam segments in the High Bay Hall, critical "outage" time on the existing beam lines, which were still in operation during the beam line expansion project, was minimized. This represented a significant cost savings to the project because outage time costs NCNR revenue from clients buying beam line time for their experiments. The temporary alignment of D Hall components was also necessary due to significant amount of demolition and concrete work required in the utility hall to prepare it for the new beam lines. The new guide hall (G Hall) was used to stage the vacuum assembly during temporary alignment. Control points, initially valued for the beam lines to be set in the new guide hall, were used as temporary control to locate the D Hall components prior to movement into the D Hall upon construction completion. Figure 12 is the CAD rendering of the D Hall components aligned in the G Hall prior to movement. This temporary alignment is expected to save several weeks on the critical path of the beam line expansion schedule. The only significant risk remains the potential movement of beam segments within the vacuum vessels as they are moved into the D Hall. Steps have been taken to move the vacuum vessels on air bearings to minimize the potential for movement of any aligned components.
Another major challenge for the NCNR alignment team was installing the beam line vacuum vessels containing the glass beam segments in their final positions. The process started with the installation of the new reactor penetration, called an "inpile." The inpile installation exposed the alignment team to potential radiation and had to be completed as quickly and efficiently as possible. The installation was critical because it was the first component that set the direction and orientation of the beam lines and had to be set to coincide with the concrete wall penetrations established between the Reactor Hall and the Utility Hall. Figures 13A and 13B show the inpile before and after installation in the reactor face. Figure 13A shows the separation of the neutrons into four distinct segments prior to departing the reactor and entering the beam lines. The image on the right shows the inpile installed and several fiducials located around the collar to be used for alignment and valuing additional control points relative to the inpile. Once the inpile was in place and the concrete wall penetrations were completed (see figure 6), the C Hall components could be transferred into the Reactor Hall and accurately located (see figure 11). This process was facilitated by placing fiducials on the vacuum vessel jackets. These fiducials, shown in figure 14, were valued after the glass beam segments were installed, which allowed indirect measurement of the beam segments without removing the covers on the vacuum vessels. With the Reactor Hall vacuum vessels installed, the process could proceed to installing the D Hall vacuum vessels initially aligned in the main guide hall (see figure 12). The challenge with this installation was that the final D Hall height is only 5 ft from floor to ceiling. The floor was raised to accommodate utilities that needed to be run under the vacuum vessels. This area, affectionately referred to as "the bunker," allowed for very little access room. The control network for D Hall also presented difficulties because visibility within the room is severely restricted. This necessitated placing some of the control points on the ceiling to maximize visibility. The final step was installing the vacuum vessels and glass beam guides in the guide hall. Figure 15 gives a good overhead view of the three areas. With the completion of the installation of the guide hall vacuum vessels, the primary alignment tasks were completed, and the only remaining task was to install the experiment equipment for each of the four beam lines.
A remarkable aspect of the beam line expansion project, other than the need for the highest level of accuracy, the need to work on the periphery of the project construction areas, and dealing with severely limiting visibility constraints, was the fact that all of the NIST personnel performing the alignment planning and measurements had no previous experience with metrology or alignment. This lack of experience, though initially intimidating, also meant that no bad habits had been ingrained. The operators were taught to run portable CMM arms, laser trackers, total stations, digital levels, and the NRK SA software platform. The training also included best practices in the use of metrology equipment and alignment techniques for accurately setting components using a control network. The success of the alignment process thus required a significant amount of careful planning, hands-on training using actual beam line components, and guidance from an experienced metrology expert to ensure the effort stayed on target and avoided common pitfalls that would only be known to someone who had worked in the alignment arena for many years. ECM Global Measurement Solutions (ECM) was privileged to be asked to assist with the NCNR beam line expansion project. The guidance came in the form of project site reviews, procedure development, automated measurement function development, and on-site training of the alignment team. Of these efforts, the development of a specific alignment plan and procedures was one of the most critical elements. ECM personnel wrote a project plan that was used as a template for the alignment team. Included in the project plan was a step-by-step approach to planning each measurement task and coordinating alignment requirements with the other disciplines on the project as well as with the design engineers responsible for vacuum vessels. This coordination ensured that when the time came for positioning beam segments and vacuum vessels, visibility restrictions were taken into account and provisions made for optimizing line-of-sight to critical components. Additionally, where the complexity or repetitiveness of a measurement task necessitated a guided approach, software routines were developed that would step the lab technicians through the measurement task and perform the computations automatically. Figure 16 provides an example of where the NRK SA software was used to automate the measurement of each beam line segment, directing the operator of the portable CMM arm to which points to measure, in which order, and then computing the alignment and transforming the fiducials into project coordinates. This level of scripting or automated measurement not only simplified the measurement task but also eliminated many manual data entry steps that were potential sources of measurement error. The use of NRK SA software also provided a visual guide during each of the measurement tasks where the lab technicians could see the data as they collected them and verify that the points were taken per the measurement plans and procedures. Seeing the lab technicians develop into a first-rate measurement and alignment team remains one of the most significant accomplishments of the NCNR beam line expansion project. The success of the project hinged on their capabilities, and they delivered with both the discipline and determination to meet the project challenges.
The NCNR alignment team faced several daunting challenges during the installation of the new beam lines while the main facility was still operating. Working adjacent to areas where active neutron experiments were being conducted required careful planning and execution to avoid testing interruptions. The team also had to ensure the project met its accuracy, schedule, and cost targets. That all this was accomplished by lab technicians and engineers with little or no formal metrology or alignment training is a remarkable feat and reflects well upon the quality of the engineers and technicians assigned to the alignment team. The team's ability to install and value the highest-order accuracy control network, using multiple measurement technologies such as portable CMM arms, laser trackers, and levels, demonstrated a great aptitude for acquiring new skills and performing them at a very high level. Their willingness to work on the most critical tasks while delegated to performing them in whatever available space was on hand in adjacent areas to the main construction site is a credit to the team. The planning behind placing the fiducials in the most visible locations on the beam segments and vacuum vessels and incorporating the location into the CAD designs for optimizing the alignment process showed a thoroughness not commonly found on complicated alignment projects. And to accomplish all this with a crew of technicians and engineers with no previous metrology experience was quite extraordinary. Clearly, though the project presented significant alignment challenges, the NCNR team was up to the challenge and demonstrated the skills necessary to ensure a successful installation of the new beam lines. Quality Digest does not charge readers for its content. We believe that industry news is important for you to do your job, and Quality Digest supports businesses of all types. However, someone has to pay for this content. And that’s where advertising comes in. Most people consider ads a nuisance, but they do serve a useful function besides allowing media companies to stay afloat. They keep you aware of new products and services relevant to your industry. All ads in Quality Digest apply directly to products and services that most of our readers need. You won’t see automobile or health supplement ads. So please consider turning off your ad blocker for our site. Thanks, Ray Ryan, director of business development for ECM Global Measurement Solutions, has been involved in the metrology field for more than 28 years, working for several companies representing a broad spectrum of industries from aerospace to metrology equipment manufacturers. His technical experience includes photogrammetry, theodolites, total stations, laser trackers, fixed and portable CMMs, laser radar and indoor GPS systems. His specialty is the design and implementation of metrology solutions for aerospace and energy research.Challenges of Neutron Guide Alignment at the NIST Center for Neutron Research
Definitions
• NCNR—NIST Center for Neutron Research, located in Gaithersburg, Maryland
• Fiducials/fiducialize—Reference points valued relative to key feature or datum
• Control network—A series of points measured to a high degree of accuracy and used to position key components within the project reference system
• USMN—Unified Spatial Metrology Network
• Bundle adjustment—Mathematical calculation to combine multiple measurements based on equipment accuracy, redundancy of measurements, and measurement geometry.
• 3-D transformation/best fit—Mathematical calculation to align two sets of dataOverview
Figure 1: NIST Center for Neutron Research (NCNR) beam layout (new and existing)Challenges of beam line expansion
• Characterizing glass beam segments
• Aligning C and D Halls' components in temporary location
• Positioning vacuum jacket assemblies into final locations
• Using nonmetrology personnel to perform all alignment tasksEstablishing a facilitywide control network
Figure 2: New River Kinematics (NRK) Spatial Analyzer (SA) software screen shot of control network
Figure 3: Measurement devices: (A) laser tracker, (B) total station, (C) digital level
Figure 4: Spatial Analyzer (SA) software simulation of proposed instrument locations
Table 1: New River Kinematics (NRK) Spatial Analyzer (SA) software Unified Spatial Metrology Network (USMN) data-reduction results
Figure 5: Neutron reactor in C Hall
Figure 6: View from C Hall to D HallCharacterizing glass beam segments
Figures 7 A and B: Glass beam segments with fiducials and interior view
Figure 8: Portable CMM arm measuring beam segment and fiducials
Figure 9: CAD image of vacuum vessel with beam segments and fiducials
Figure 10: Beam segments installed in vacuum vesselAligning C and D Halls' components in temporary location
Figure 11: Assembled Reactor Hall vacuum vessels with wall penetration plate
Figure 12: D Hall vacuum vessels temporarily assembled in guide hallPositioning vacuum jacket assemblies into final locations
Figures 13 A and B: Inpile before and after installation in reactor face
Figure 14: Reactor Hall vacuum vessels with fiducials
Figure 15: Reactor Hall, D Hall, and guide hall spatial relationshipUsing nonmetrology personnel to perform alignment tasks
Figure 16: New River Kinematics (NRK) Spatial Analyzer (SA) measurement plan for measurement automationConclusions
Quality Digest Discuss
Ray Ryan
